ccl2flow.exe error
Old   August 24, 2023, 08:18
Unhappy ccl2flow.exe error
Douglas Tiago Hardt
douglasdth is on a distinguished road
Hello. I'm trying to simulate the airflow of a cetrifugal fan, it's a rotating domain in ANSYS CFX 16.0. I've run several similar models but this time the following warning appeared:
An error has occurred in cfx5solve:
C:\Program Files\ANSYS Inc\v160\CFX\bin\winnt-amd64\ccl2flow.exe was interrupted by signal HUP (1)
Update failed for the Solution component in Fluid Flow (CFX). The solver failed with a non-zero exit code of : 2
Usually the error "non-zero exit code of : 2" refers to the quality of the mesh. But what I'm not understanding is what would be the warning referring to "ccl2flow.exe."
Would anyone have a tip to help me?
douglasdth is offline   Reply With Quote
ccl2flow.exe, centrifugal fan, exit code
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
