December 4, 2023, 23:19 |
Rough plate geometry meshing
Rana abdo
Rep Power: 3 |
If i have a rough solid plate geometry with length 1.5 m having micron peaks and vallys on it how can i mesh the micron peaks and vallys without having too many cells i choose a mesh size of 0.0001 m but i need to capture even the smallest peak and vally is there another way of meshing such geometry
I am using ansys fluent meshing. |
December 5, 2023, 02:26 |
Alex
Rep Power: 47 |
You can not explicitly simulate roughness with such a difference in length scales.
Depending on what you are interested in, either decrease the extent of your simulation model. Or look into wall roughness modeling for turbulence. |
fluent, mesh 3d, roughness |
[ICEM] Meshing a fractal geometry in ICEM | andrewmichael | ANSYS Meshing & Geometry | 0 | May 22, 2018 20:17 |
Dynamic Meshing of Simple 2D Geometry | harman79 | FLUENT | 2 | January 17, 2018 06:07 |
[ICEM] Problem Meshing Asymmetrical Geometry | Madhatter92 | ANSYS Meshing & Geometry | 1 | December 23, 2017 05:56 |
Meshing Pipeline: Swapping Geometry, how to update Regions/Boundaries | matzeee | STAR-CCM+ | 3 | June 18, 2017 09:31 |
[ANSYS Meshing] Using more than one meshing method on a single 2D geometry | robbierich90 | ANSYS Meshing & Geometry | 0 | October 30, 2011 13:12 |
