Insight required on Two way fsi with multiphase flow
Old   January 6, 2024, 15:58
Default Insight required on Two way fsi with multiphase flow
Mak25 is on a distinguished road
Hi, I am trying to simulate a popet valve used in aircraft landing gears. The valve is a spring based valve that opens and closes based on fluid and spring pressure. Additional for the nose gear there is a separator between the fluids oil and nitrogen however for main there is no separator and mixing occurs. I would be glad if I could get some insight on how you would approach this problem as the valve closes due to spring load and opens with fluid pressure.
I am at an intermediate level with openfoam having run a few cases with exterior flow over aircraft bodies however I have never done fsi and am open to learning/using it. I also have access to MSC One which gives me access to msc marc nastran and cradle with cosim. Any help is greatly appreciated.
Mak25 is offline   Reply With Quote
fsi 2-way coupling, movable mesh, multi domain, multiphase, opefoam
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
BC problem with Eulerian-Eulerian Multiphase Flow ngoc_tran_bao CFX 4 September 24, 2016 04:43
Freelancer required for Multiphase flow simulation of beer in pipe with pumps akash27 CFD Freelancers 0 August 9, 2016 14:29
Multiphase flow in atomiser santhosh1987 FLUENT 0 May 12, 2011 04:26
Simulation of air flow inside valve - FSI? Help! farianka Main CFD Forum 0 April 17, 2011 16:30
