Modeling shear-thinning medium: Temperature drop
Old   January 11, 2024, 05:58
Question Modeling shear-thinning medium: Temperature drop
Simon
SimonH is on a distinguished road
Hello everyone,
I'm posting my question here because it doesn't fit into any other sub-forum. It's about the physical background of my test simulation.
I am simulating a simple pipe with an orifice plate. The pipe has a diameter of 18 mm. The orifice has a very small opening of 0.1mm. A shear-thinning medium (liquid plastic) is pressed through the opening. The mass flow inlet is on the left of the pictures. The mass flow was set to 573K (!). The pressure outlet is on the right.
[Picture: Geometry]
Since I have heard that the Cross-WLF model is the most accurate way to map a shear-thinning medium, I used a predefined Cross-WLF medium.
The result (pictures below) is generally OK. Only the temperature confuses me, as it is significantly colder (557K) at the inlet than at the outlet (573K). The way I see it, the temperature on the left side should be the same or higher, because the pressure on the left side is higher and the density is the same.
[Picture: Temperature]
Now to my question: How is the Temperature-Drop to explain? And is there a physical law that can explain the lowering of the temperature in the first chamber?
What I have already tried:
- Higher mesh resolution - same result
- Different model approach of the shear-thinning medium - same result
- Simulation with water - temperature remains constant
I am looking forward to your suggestions
Thank you very much in advance.
All other important variables are listed below:
[Picture: Fields]
SimonH is offline   Reply With Quote
drop, shear, shear-thinning, temperature
Averaging over iterations for steady-state simulation CFD student Fluent UDF and Scheme Programming 8 September 22, 2022 03:39
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Estimating pressure drop from the shear stresses K.Baker FLUENT 2 July 26, 2007 03:56
modeling of shear thinning Dominik Main CFD Forum 1 July 13, 2005 10:05
Temperature drop after porous zone MN FLUENT 0 December 10, 2003 12:28
