January 15, 2024, 03:22 |
I have question in implementing LES code
JAE SANG RHEE
Rep Power: 11 |
Hi
I am trying to implement Large Eddy Simulation code for our in-house CFD code for compressible flows. Most of all, I'm really confused in treating Filtered Navier-Stokes Equations (FANS) whether they are compressible or not since I have only programmed for Inviscid or RANS solver. Generally, vector for physical variables for FANS is Filtered variables. Then, can I get solutions from FANS directly using SGS models? Is Flitering used only for recasting Navier-Stokes equations??? I thought it isn't since various filters are used for LES for incompressible flows Sorry for my rambled question Thanks in advance |
January 15, 2024, 04:13 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Generally, you can see that a lot of LES codes use the so-called "implicit filter", that is both the computational grid size and discretization of the equations act as filter for the unresolved solution. For example the FVM is used as implicit top-hat filter. On the other hand, some SGS models such as the dynamic procedure, scale similar, require to code an explicit filter to compute the test-filtered fields. Since you programmed the code for the inviscid case, I suppose you have a weak formulation, that is a volume integral solution. In such a case you can suppose this is your filter and you have to supply the equations with the SGS model. Note that often codes for inviscid compressible flows have some flux limiter or similar, there is also a LES community using that as implicit SGS model in the so called ILES. |
January 15, 2024, 04:23 |
#3 | |
JAE SANG RHEE
Rep Power: 11 |
Then, FVM is alrealy implicit top-hat filtered equations and if I Solve FVM with SGS models, then LES solution can be obtained??? |
January 15, 2024, 04:27 |
#4 | |
Rep Power: 71 |
You have to check your solution on well known test-cases. |
January 15, 2024, 04:31 |
#5 | |
JAE SANG RHEE
Rep Power: 11 |
so many Thanks .. |
Question about LES | lucamirtanini | Main CFD Forum | 7 | October 19, 2021 12:46 |
Implementing Boundary conditions for a LES simulation | samurai_01 | Main CFD Forum | 22 | October 3, 2016 13:38 |
Question about LES | fivos | Main CFD Forum | 7 | May 17, 2013 05:10 |
2-equation model of LES and source code | M.R.Hadian | Main CFD Forum | 0 | February 3, 2002 05:00 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
