CFD/FEM and MATLAB
Old   August 29, 2000, 07:59
Default CFD/FEM and MATLAB
clifford bradford
Does anybody have CFD/FEM related links using MATLAB? I've been working on postprocessing 2D result from a CFD code I have with MATLAB and I've been relatively succesful (in my opinion) and I'd like to get hold of more tools for CFD/FEM which use MATLAB.
Old   August 30, 2000, 22:14
Default Re: CFD/FEM and MATLAB
Istadi
I think, MATLAB has powerfull software to get online visualization of the computation result and we get smooth graphic line. It have an advantage for online visualization. However, it have a detriment that the code developed can not compile to executable file. So, we need always the source MATLAB to run code.
Old   August 31, 2000, 04:13
Steve Amphlett
I think you'll find that the MATLAB compiler can generate standalone code that can run independently from MATLAB.
Old   August 31, 2000, 13:58
clifford bradford
Istadi, I'm aware of the strengths and weaknesses of MATLAB and you're wrong: MATLAB has an optional compiler that allows you to translate your MATLAB code to C/C++ code. check out their homepage http://www.mathworks.com
anyway-do you have links to MATLAB CFD/FEM codes or utilities?
Old   September 1, 2000, 22:42
istadi
I have build the source code for CFD/FVM or CFD/FDM, but I have not yet build it in MATLAB code. So, as I know that MATLAB can't be compiled to executable file. If you can do it, please tell me about it. Must we convert the F90 code to C++ to get the executable file ? Is it easy to do ? Thank for your oppinion.
Old   September 2, 2000, 00:56
joel guerrero
try this link: http://www.cs.cornell.edu/Info/Peopl....0/patch2.html
Old   September 4, 2000, 14:53
clifford bradford
As far as I know you write the code in Matlab and the converter translates it into C++ which is then compiled. i suppose if you had code written in F90 then there'd be no reason to go the MATLAB route. if you want more info you should go to http://www.mathworks.com
How to start Fluent with Matlab?? Jay Hu FLUENT 8 November 9, 2022 06:30
Pohlhausen energy equation MATLAB help abe_cooldude Main CFD Forum 2 May 3, 2010 16:58
[ICEM] version 12 incompatible with MATLAB R2009 siw ANSYS Meshing & Geometry 1 September 8, 2009 09:20
caling matlab in Fortran HaKu Main CFD Forum 0 July 16, 2009 15:35
MATLAB FORTRAN Ally Main CFD Forum 4 July 12, 2007 03:51
