Simulation of flow at very low Reynolds number using Reynolds number |
February 11, 2024, 21:40 |
Simo Med
Rep Power: 2 |
Edit: I realized that there is a typo in the title. It should be: Simulation of flow at very low Reynolds number using RANS
__________________________________________________ __________________________________________________ __ Hi I need to run a simulation of the flow around an airfoil (Reynolds number based on the airfoil chord is only about 890). But the inlet of the domain has a turublence intensity of 0.6%. I have limited computing power, so I can afford only relatively small simulations. I have some questions. - Can I use a RANS turbulence model for this case? - If I use laminar flow (without a turbulence model) how can I include the effects of inlet turbulence intensity? Thank you for your help. Last edited by SimoY; February 12, 2024 at 10:38. |
February 15, 2024, 18:53 |
Simo Med
Rep Power: 2 |
Could someone please provide some comments.
Thank you |
February 16, 2024, 07:14 |
andy
Rep Power: 18 |
Turbulence is dissipated by viscosity in low Reynolds number regions. The PhD project in the 70s that first introduced the k-e turbulence model was on the subject of relaminarization of turbulent shear layers. It is doable.
Almost all general 2 equation (or more) RANS turbulence models assume the Reynolds number is high. Models that are intended to be used in low Reynolds number regions are almost always tuned to be valid for only one specific type of flow. No general RANS model is going to be valid for the low Reynolds number flow over your aerofoil. Whether the free stream unsteadiness is significant is likely to depend on the information you want from the simulation and/or the form of the unsteadiness (wakes?). A reasonably accurate unsteady simulation of the flow over your aerofoil is likely to be viable on a modern desktop (subject to the relevant physics). It might take a few days for the statistics to settle down. I suspect the biggest problem is likely to be how to impose representative unsteady inlet conditions. |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
Seakeeping Solver:Crashed | akbarbagusd | Fidelity CFD | 0 | November 5, 2021 12:42 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Turbulence model for low Reynolds number flow? | Nokadu | Main CFD Forum | 3 | May 26, 2013 11:42 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
