February 29, 2024, 11:39 |
Aeroacoustics modelling
Rep Power: 5 |
Hello!
I am trying to start a CFD case which involves two key requirements that I would assume will influence the modelling technique used. I want to simulate far field noise data for an airfoil that is equipped with mechanical blowing in certain parts of the airfoil. I have found several useful papers on simulating either one, but am struggling to find resources that include both and would appreciate some guidance on this. For more context, the flow is subsonic, with no BL tripping and simulation should be 3D or atleast quasi-3D Thank you |
February 29, 2024, 15:56 |
Lucky
Rep Power: 66 |
Aeroacoustic modeling is a post-processing step after you simulate the flow. So you don't need a paper that does both. If you have papers that show you how to do Step 1 and then Step 2, just combine the knowledge you have gained and you can step Step 1 and Step 2. Hint, step 2 comes after step 1.
active flow control, aeroacoustics opt., airfoil 3d, noise |
How much does the source code for this turbulent flow CFD code worth in US $? | Dr Youssef Hafez | Main CFD Forum | 43 | January 4, 2023 01:13 |
Low-Re Modelling | doerschlott | OpenFOAM Running, Solving & CFD | 4 | June 23, 2022 06:53 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM | hjasak | OpenFOAM Announcements from Other Sources | 2 | February 13, 2017 04:59 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
