Help needed for calculating Specific Impulse
Old   September 20, 2000, 23:30
Default Help needed for calculating Specific Impulse
Dongsuk Chae
Hi guys,
I recently work on nozzle flows of various geometries by CFD method. Reading related papers, I found that Isp(specific impulse) of nozzles is expressed by the ratio of an ideal specific impulse. I'm wondering how we obtain the idela specific impulse of a given nozzle. Plz, suggest me the method or related papers and books. Thanks in advance.
Old   September 21, 2000, 03:44
Default Re: Help needed for calculating Specific Impulse
A. Taurchini
By definition specific impulse is
Isp=T/mf
where T is total thrust and mf is the mass of expelled propellent. Now the calculation of thrust depends on which kind of propulsion you use. For example if your nozzle is for a rocket system, then (in adapted condition : pext=pamb)
T= mf Vext
where Vext is the exhaust velocity that depends essentially from which kind of fuels and oxydizers you use. For this case is obviously
Isp=Vext
This is valid ONLY for rocket system. If you need more informations mail back. Bye.
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Specific heat in STAR-CD Andrew Siemens 3 September 3, 2009 23:33
