January 29, 2001, 10:26 |
Gambit
Hi I recently finished some work on channel flow, creating the geometry, mesh and boundary conditions using gambit and then exporting the mesh to run into Fluent. Now i have to do the same for a pipe flow but i'm abit confused in creating the geometry for the pipe. I'm getting three faces for the inlet and outlet and the whole pipe as the third face. What i really want to do is to specify the walls and consider the axisymmetry as i didn't for the channel in the boundary layer setting. Can i achieve that?
i would like your help. Chris. |
January 29, 2001, 10:27 |
Re: Gambit
January 29, 2001, 12:08 |
There is a Fluent Forum created for you ,NOT HERE
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Does Gambit has a maximum allowable grid number? | spartan1516 | ANSYS Meshing & Geometry | 7 | March 25, 2010 09:08 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
between IDL Gambit and rhino, any help? | philip | FLUENT | 0 | June 23, 2005 12:08 |
