Choice of element
Old   March 1, 2001, 05:45
Default Choice of element
Stephane Gasser
In order to develop a specific code for homogenization of a porous medium, I need to know what kind of finite elements I should use. The basic problem is a Stokes equation in 3D, and I have read that in 2D, one should use at least a triangle with 3 vertices as nodes for the pressure, and one more in the middle of the triangle for fluid speed. Is that true, and why ? And most important for me, what about a tetrahedron ?
Old   March 1, 2001, 07:51
Default Re: Choice of element
Sebastien Perron
1) The choice of elements depends on the geometry. In 3D, you could use tetrahedron or unstructured-hexahedron
2) If the flow is incompressible, the degrees of liberty for pressure and speed should not be placed at the same location. This can be done in many ways. As, an exemple, for a tetrahedron (or an hexahedron) the DOF for speed can be located at the center of gravity of the faces, and on the vertices for the pressure.
This as to be done to avoid false pressure modes.
3) This is a lot of work, Why don't you use an existing code?
[Gmsh] gmshToFoam unhandled element flowris OpenFOAM Meshing & Mesh Conversion 4 February 20, 2023 17:50
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 04:35
autoPatch error, mesh quality related...? Alexvader OpenFOAM 0 October 6, 2011 17:57
[Gmsh] Gmsh and element size factor msarkar OpenFOAM Meshing & Mesh Conversion 0 May 2, 2011 02:55
