modeling of small size cylinder
Old   March 2, 2001, 03:54
Default modeling of small size cylinder
Tim
Hi I am thinking of the flow patten around a cylinder with diameter of 0.1-0.2 mm in air. What will you expect about such flow field? Is there any differences from normal size cylinder. Thanks.
Old   March 2, 2001, 14:00
Default Re: modeling of small size cylinder
John C. Chien
(1). Flow over a cylinder means: velocity of the flow, property of the fluid, and the size of the cylinder must be given to define the problem. (2). In your case, only one parameter is given. (3). What are the missing parameters? (4). From there, you can at least define the Reynolds number, Re=Rho*U*L/mu. (5). The flow pattern will be a function of the Reynold number.
Old   March 2, 2001, 20:48
Tim
Thanks for replying. Let me specify my question: Say when Reynolds Number is is larger than 1 or 30, there will be wake region. But when the size is so small, can we still imagine there will be wake as those in normal size cylinder?
Old   March 3, 2001, 02:12
John C. Chien
(1). It is a function of the Reynolds number of your problem, it is not a function of the diameter of the cylinder.
Old   March 10, 2001, 08:26
Default fluid analysis inside a two stroke petrol engine
muthu narayanan
i'm doing my project on flow inside a 2-stroke petrol engine.i would like anyone to help me in developing a moving grid(piston).is there any online articles available for the same.
Old   March 10, 2001, 13:28
Default Re: fluid analysis inside a two stroke petrol engi
Dean
Check out www.erc.wisc.edu/index.html.
Unstable spray for small mesh size (dieselFoam) namCFD OpenFOAM 2 August 13, 2010 15:51
creaction of a very small cylinder toni Siemens 2 July 23, 2004 12:04
Modeling flow acros circular cylinder Zhihua Main CFD Forum 3 April 20, 2004 11:16
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
