In computing bouyancy induced or bouyancy affected flow, many worker employed boussinesq approximation in their computational model. If computation is performed using assumption that density is related to local pressure and temperature, it is give more accurate modelling as I understood that the above approximation is valid at certain range of flow and fluid conditions.
Thank you A. Aziz Jaafar |
Boussinesq approximation is for the problems that the variations of temperature as well as the variations of density are small. In these cases, the variations in volume expansion due to temperature gradients will also small. For these case, Boussinesq approximation can simplify the problems and save computational time.
After Gray DD. y A. Giorgini (1978), The validity of the Boussinesq approximation for liquida and gases, Int. J. Heat Mass Transfer, 19, pp 545 551,
you can safely use the Boussinesq approximation for the next temp. ranges: water app 2 K, air app. 20 K. You can also extend the B. approximation introducing the variation of some termophysical properties while others stay constant. It depends on the temp. range to be calculated. The influnece of pressure variation (after G. and G., analysis applied on water and air)is orders of magnitude less important. |
#4 | |
zhangmin
Rep Power: 16 ![]() |
I read your answer, can I ask you some questions? Fluent is very new to me.You said that when the variations of temperature and the variations of density are small we can use the Boussinesq approximation. Is there a criterion about the small and large?Thanks a lot!
![]() Quote:
Fluent consider the density constant in the Boussinesq approximation for all the terms
except for the buoyancy. that means that density variation due to thermal effects is calculated as (r- r0)*g = - r0*B*(T-T0)*g where r is the density, r0 is the density at reference temperature T0 g is the gravity; B is the thermal expansion coefficient and (T-T0) is the gradient temperature. This relation produce a variation of density due to variation of temperature. I have try to understand which percentage variation of density can I accept to validate this fluent assumption, that means in your case how much is (r-r0)/r0 ?? which value you can consider still ok?? For big temperature variation I have also used the "Incompressible-ideal gas" model that gives good results too. hope it helps |
zhangmin
Thanks a lot for your help! Now I am doing something about the incomressible ideal gas in a Closed Domain, using the Boussinesq. I have some questions which I hope can get your help. In the material panel of fluent,
1.After I choose the Boussinesq in the density panel, how can I establish the density, Cp, absorption coefficient and thermal expansion coefficient?And where can I find these coefficients? 2.In the operating comdition panel, is the operating temperature same to the temperature when I establish the density in Boussinesq hypothesis? Thank you for a million times! |
Joe
Rep Power: 14 ![]() |
lucifer,
Did you find the answer of your questions? I do not know how to choose the value of the operating temperature. In my domain I use 290 for the lower temperature and 310 for higher value of temperature... Thank you, Hooman |
A. Min
Rep Power: 12 ![]() |
Hi all
I'm trying to solve the "transient free convection flow of water in a limited box that is driven by a constant heat flux cylinder at the middle of the box". I want to use Buossinesq Approximation in my equations. In this equation we have: gB(T-Tref) in infinite fluid domain we get Tref=Tinf. But my domain is finite! and by passing time, the fluid temperature (Tinf) will be increasing! What should I get as Tref in my equation? Thanks |
#9 |
Joe
Try your lower temperature or average temperature and compare the results.
Keep that in mind your temperature difference should not be more than 10-15 degree C to be able to use Boussinesq. Good Luck! |
#10 |
A. Min
Thanks
average of domain temp.? But my average temp. is changing by time! what is lower temp.? |
#11 |
Joe
Suppose your temperature difference in the domain is 10K (300-310 K).
Try 300(lower) or 305 (mean) and then compare the results and see which one is better. |
#12 |
A. Min
OK.
and what is my criterion for investigating which one is correct? |
#13 |
A. Min
Also you know, my B.C. is constant heat flux, so I don't know my Tmax and I can't compute Tave!
#14 |
Joe
Try to find similar works or papers of your geometry if you do not have the experimental data.
You may model that work/paper and see which simulation is close enough to the paper/work. Based on that, you can implement the same way in your modeling. |
#15 |
A. Min
Thanks again
I have investigated 115 papers. But all of them are fixed temp. or in a infinite fluid! My problem is none of them! the domain is finite and the B.C. is constant heat flux (-: |
#16 | |
Filippo Maria Denaro
Rep Power: 71 ![]() ![]() ![]() |
if your domain is finite, then you have also BC.s over all the confined walls....are you using heat flux imposed everywhere in your domain? That means you are setting k dT/dn = h (T-T0) Therefore, you can compute T0 when the temperature field is known. |
#17 |
A. Min
Thanks for your answer.
Yes, I use heat flux B.C. on walls of my domain. But in this B.C. T0 is the out temp.! e.g. if my box is full of water, T0 is the air temp. and that is 292 K. But what is Tref? |
#18 | |
Again, in the Bousinnesq approximation, you use the first order expansion: rho = rho0 + d rho/dT|0 (T-T0) T0 is the assumed temperature around which the constant density rho0 has variation depending on the small temperature variation. The assumption requires few degree of temperature variation. In your case you have to assume the value T0 based on the problem. From what you wrote, I cannot immagine you have an entering heat flux imposed on all the wall simply because it is physically impossible that you temperature goes to infinity via via the time passes. |
#19 |
Giovanni Fiorillo
Rep Power: 8 ![]() |
I have a question about the temperature variation allowable in boussinesq. I've always heard/read one of the following:
I just recently read somewhere else that as long as your density varies linearly with temperature of the range in which you domain operates within, then boussinesq can still be applied. To me this doesn't seem correct because the buoyancy/gravity force used for boussinesq is: - ![]() ![]() Where To is you reference temperature and ![]() Also, just to make sure I am understanding boussinesq correctly, when T = To, the buoyancy term becomes zero. So, at any point in out domain where we have a temperature of To, there is no buoyancy force at that location, correct? I believe if this statement is true, then what I have stated above must also be true. I do agree that the density versus temperature must be fairly linear for the temperature range for boussinesq to be applicable, but this isn't the sole requirement when it comes to temperature ranges, as they must also be reasonably small, whatever that means. I guess I'm looking for some additional insight; someone to tell me my understanding is correct or perhaps someone needs to lay the knowledge hammer down me. Look forward to hearing some responses! -Best ggfiorillo |
#20 |
(T-T0) cannot increase as you want, this difference must be small to use the linear apporximation
InterFoam with boussinesq approximation | sinusmontis | OpenFOAM Running, Solving & CFD | 2 | October 25, 2020 12:21 |
Boussinesq approximation, help please! | engahmed | FLUENT | 0 | May 20, 2010 11:25 |
Question on boussinesq approximation | panos_metal | FLUENT | 1 | January 11, 2010 11:18 |
boussinesq approximation | jamal | FLUENT | 2 | March 25, 2008 08:57 |
Boussinesq approximation again | Gabriel | Main CFD Forum | 3 | May 11, 2000 09:24 |
