Coal combustion in a fixed bed
Old   May 19, 2001, 18:16
Default Coal combustion in a fixed bed
Ghabi
Can you please tell me how to shose the boundry conditions in a fixed bed combustion of coal. Thanks
Old   May 20, 2001, 01:38
Default Re: Coal combustion in a fixed bed
John C. Chien
(1). If you don't know what to do with the boundary conditions, then try to simulate it as if you are running the test. (2). In the testing, you will have to know something, or measure something, and that will give you the boundary location and conditions. (3). Apparently, you can't specify the condition at the surface of the coal. It is burning and the surface is most likely irregular. (4). So, you need to define the inlet conditions and location away from the coal bed. You also need to model the coal bed so that you can simulate the coal burning.
Old   June 7, 2001, 10:41
I. Dotsikas
Hallo
actually fixed bed reactors are very important in chemical engineering. There is a vast amount of research articles in almost any chemical journal. From such sources you can see how the equations look like, and set up your own equations that describe the funktion your a fixed bed. for example: do you have to calculate axial diffusion in your fluid?
By the way do you use one , two or three dimensional equations? There are some very important approximations like the Vortmayer description of the flow field in a fixed bed reactor, that might be quite usefull to you.
best regards,
Jannis
Coal gasification - Eulerian - Fixed bed oliveagp FLUENT 23 May 3, 2018 13:30
Coal combustion and ash reaction kinetics sega Fluent UDF and Scheme Programming 0 January 21, 2010 08:05
fixed bed combustion Adi FLUENT 7 April 19, 2001 01:20
Fixed Bed Combustion Stanley FLUENT 21 March 22, 2001 10:18
Combustion of Solids in fixed bed Ghabi Chekib Main CFD Forum 1 December 20, 2000 04:05
