November 3, 2001, 03:25 |
FDM in Cylindrical Coordinate
Anybody ever try Finite Difference Method on Cylindrical Coordinate? or know where can I get information about this?
Piakman |
November 3, 2001, 04:43 |
Re: FDM in Cylindrical Coordinate
'where can I get information about this? ' Books authored by (1) Carnahan, Luther and Wilkes and (2) Patankar
November 3, 2001, 05:56 |
There are a couple of papers about FDM in Cylinderical Coordinates.
"A Finite-Difference Scheme for Three-Dimensional Incompressible Flows in Cyliderical Coordinates" R. Verzicco and P. Orlandi 123, 404-414 (1996) "Simulation of Viscoelastic Fluids: Couette-Taylor Flow Raz Kupferman Journal of computational physics 147, 22-59 (1998) Numerical Simulation of Axisymmetric Free Surface Flows M. E. Tome, et at. Journal of computational physics 157, 441-472 (2000) You may visit my website, recently a couple of simulations has been done and compared with experiments. http://www.ima.umn.edu/~junkim/jet.htm Junseok |
November 3, 2001, 08:31 |
For several decades, the T-3 group at Los Alamos (http://t3.lanl.gov/) developed codes that included the cylindrical coordinates option by changing a single parameter from 0 to 1 [0 gives the usual Cartesian coordinate system].
Check their web site. |
November 4, 2001, 19:29 |
"Fluid Flow Phenomena" A Numerical Toolkit
edited by Paolo Orlandi Ch. 10 Flows in cylindrical coordinates with one wall Ch. 11 Flows in cylindrical coordinates with two wall There are source codes. You can also test the example problems of the book. |
November 26, 2001, 05:16 |
I want to order the book
fluid flow phenomena "A numerical Toolkit" Can you tell me the year of publication and the publischer ?? Thank You |
November 26, 2001, 05:17 |
November 26, 2001, 05:38 |
I'm using a new Finite difference method by Strikwerda.
The method is 2nd order in space and time and has schon good results with laminar flow test cases. The uses non staggered grid and solves the conti. and momentum eqns. simultaneously with an iterative solver (implicit). --------------------------------------------- I'm trying to use the scheme to simulate fully developed turbulent pipe flow in cylindrical coordinates. At the inlet and outlet of the pipe I use periodic boundary and wall boundary at the wall of the pipe. The pressure is calculated with extrapolation at all boundaries. --------------------------------------------- And I have a question concerning the Boundary condition at the middle of the pipe. At the middle of the pipe there exists a singularity because of the finite difference method used. This means I have to implement an artificial boundary condition. I use Neumann boundary conditions for velocities ( The gradient of velocities perpindicular to this boundary is zero) Does any one have any other suggestion ?? Thank You |
November 26, 2001, 10:14 |
KLUWER ACADEMIC PUBLISHERS
The author's e-mail address is as follows; orlandi@navier.ing.uniroma1.it |
cylindrical coordinate vs cartesian coordinate | Lam | FLUENT | 10 | May 11, 2013 13:05 |
cylindrical coordinate -Gambit | noussa | ANSYS Meshing & Geometry | 2 | June 12, 2010 09:07 |
CFD Software with Cylindrical and Spherical Coordinate | cfd2010 | Main CFD Forum | 0 | June 9, 2010 21:55 |
singularity problem in cylindrical coordinate | dallybird | Main CFD Forum | 6 | June 3, 2003 11:47 |
Cording Ground.for in Cylindrical coordinate | J.H. Lee. | Phoenics | 2 | March 28, 2003 04:28 |
