Dec Alpha Workstation + Linux
Old   February 22, 2002, 17:53
Default Dec Alpha Workstation + Linux
Ray
Dear there,
I am using Dec Alpha workstation. The red hat linux version 7.0 is being used as the operating system.
I am doing gas-liquid two-phase flow with free surface. The computation goes on well, but when there is surface tension force, or the PLIC subroutine (based on the Young's algorithm) is used instead of the Donor-Acceptor scheme is used, the computation crashed. The error message is:
float processing error.
I had same problem when I used the PIII-733 with red hat linux version 6.2. But when I used the linux version 7.0 (and above), the problem solved.
Did you have same experience?
Your help will be highly appreciated.
Ray
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 16:49
Works in Red Hat Linux 6.2 with Alpha Processer? hongchan FLUENT 1 December 24, 2001 17:32
Alpha to be phased out Heiko Gerhauser Main CFD Forum 17 July 25, 2001 14:40
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 15:01
