Reynolds number
Old   April 12, 2002, 01:51
Default Reynolds number
Mult
Could you tell me what is the significance of the Reynolds number. It is defined as
inertial force/viscous force
But what is an inertial force in fluid mechnanics
Thanks
Old   April 12, 2002, 11:02
Default Re: Reynolds number
John Dreese
The Reynolds Number is possibly the most important number in Aerodynamics because it incorporates all aspects of a flow condition: speed, density, object length, viscosity. In fact, many CFD packages don't let you enter speed, density, etc. separately; instead having you enter the Reynolds Number only.
As you mentioned, the Reynolds Number is essentially a ratio of the inertial (momentum) forces divided by the viscous forces. The inertial forces are those whose magnitude depend on speed and mass (density). The viscous forces depend on the material properties of the fluid.
As your Reynolds Number increases, this typically means that your flow speed is increasing and that boundary layer development is more likely to follow the laminar/transition/turbulent scheme. At low Reynolds Numbers (think of model airplane speeds), it is possible for the flow to go from laminar to separated; skipping turbulent development.
Low Reynolds Numbers are typically considered the most difficult to model in CFD.
John Dreese Maker of FREE Airfoil Development Software www.dreesecode.com
Problem with decomposePar tool vinz OpenFOAM Pre-Processing 18 January 26, 2011 02:17
Reynolds Number and Heat transfer Coefficient panos_metal FLUENT 0 January 7, 2011 06:37
Low Reynolds Number k-epsilon formulation CFX 10.0 Chris CFX 4 December 7, 2009 23:51
Reynolds Number Matt CFX 0 February 25, 2009 05:40
