Navier-Stokes Equation - unit problems
Old   April 24, 2002, 04:52
Default Navier-Stokes Equation - unit problems
Maciej Matyka
Hello.
I have a problem with interpreting results of numerical calculations. Let say, than i'm solving full 2D NS equation. Somebody asked me what is really size of the tank. And..
let: WIDTH and HEIGHT are the screen calculations
NX and NY are grid size (number of cells)
now i calculate DX and DY as WIDTH/NX and HEIGHT/NY
VIS is viscosity of the fluid
GY is grawity vector
DT is float delta time
now let:
WIDTH=320
HEIGHT=200
NX=32
NY=20
then DX = DY = 10 let:
VIS = 0.1
GY = -9.8
DT = 0.01
now im asking: from where i know what is size of my tank and other physically properties of my fluid model? is that determined by GY unit (m/s^2)??? i really dont know what are units of my calculations, and my results are only qualitate not quatitate.
Maciej Matyka,
author of Fluid NS solver - available at http://panoramix.ift.uni.wroc.pl/~maq
Old   April 26, 2002, 09:44
Default Re: Navier-Stokes Equation - unit problems
Francisco
Hi Maciej. As far as I´m concerned, what really matters in such a calculation is the Reynolds number (as long as effects like surface tension are negligible). That is, once you have defined the Reynolds number (which is dimensionless) for your specific problem, the units of VIS, RHO, HEIGHT and the characteristic velocity are irrelevant (take the flow between parallel plates for instance Re=U*RHO*HEIGHT/VIS). The result will be a function of Re number only. You can prove this to yourself by writing the NS equations in dimensionless form. This can be found in any book of Fluid Mechanics.
Best regards,
Francisco.
Adding a term to Navier Stokes Equation ashtonJ CFX 3 January 15, 2011 06:32
coupling KE equation with navier stokes equation prashant FLUENT 0 March 7, 2008 07:05
2d compressible Navier stokes selim Main CFD Forum 0 July 6, 2007 11:24
Navier stokes compresible viscid flow fea, somebody can help? Jose Choy Main CFD Forum 3 October 24, 2003 02:28
help: I am trying to solve Navier Stokes compressible and viscid flow Jose Choy Main CFD Forum 2 May 18, 2000 05:45
