example of NS equation
Old   June 5, 2002, 23:48
Default example of NS equation
mukkarum
Sir i am working on research project "revemping of Francis Turbine applying CFD". I have got book "An introduction to computational fluid dynamics (finite volume) by malalasakra" it is very good book and i have understand SIMPLE, SIMPLER AND SIMPLEC method of solving Navier Stock equation but in this book just presentation that how Navier Stock equation can be solved but there is no solve example. Do you know any book or article in which this type of example is present. I mean that for any given problem(good if turbine rotor)firstly assume pressure field and then find velocity field then check pressure correction equation and repeat this procedure still convergence occure. waiting for your prompt reply thanks
Old   June 6, 2002, 14:25
Default Re: example of NS equation
any
lick the ass of NS equation it will converge
Old   June 6, 2002, 15:50
alex
could you please tell us more about your exciting discovery.
Old   June 7, 2002, 00:32
Ajay S. Parihar
Dear Mukkarum, Its not worth to write same message in each thread. Try to be mature and don't display your question again and again which is irrelevant regarding that thread. If you can not give a proper explanation to any query then atleast dont make people confused with displaying 100 same messages.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Viscosity and the Energy Equation Rich Main CFD Forum 0 December 16, 2009 14:01
continuity equation Rafal Main CFD Forum 4 November 29, 2006 09:27
