SIMPLE algorithm
Old   June 19, 2002, 07:41
Default SIMPLE algorithm
jika
Hello Sirs,
I am a beginner of cfd. I am trying to solve steady, incompressible, laminar, 2D driven-cavity flow problem using SIMPLE algorithm. As I have to use pressure relaxation factor of 0.001 to get a converged solution at Reynolds Number = 100 and as I am not getting convergence for Reynolds number > 200 at this pressure relaxation factor also, I want to ask the following questions -
1)In momentum equations,
(a_P) = (summation of a_nb) + (flux difference over the cv)
this relation maynot give a diagonally dominant matrix when the solution is not converged. So I am using
(a_P) = (summation of a_nb) + MAX[0,(flux difference over the cv)]
in my program. Is it correct?
2)How to use time-stepping in this problem? How to deal with the term
(rho_p^o - rho_p).Delta V / Delta t
which arises in the transient pressure correction equation?
My 100 Re result is matching very well with benchmark solution. I have tested different grid sizes (uniform) from 10x10 to 100x100. I am using upwind scheme for covective terms.
I have read the previous discussions on SIMPLE algorithm here. I have gone through the books by Peric, Patankar, Malalasekera. But still I am not clear on these points. Where I may be wrong? Please help me.
Thanking you in anticipation.
jika
Old   July 3, 2002, 12:50
Default Re: SIMPLE algorithm
arash
hi jika I had some problem like you but about 1 think That's not correct.flux difference over the cv has a physical meaning and you can not delet it in some equation. about 2 there is a code that Peric developed it. you can get it and compare your code with it .you can learn many things about SIMPLE algorithm in those codes.
Old   October 22, 2009, 06:46
mhm
mhm
mhm is on a distinguished road
Hi
I suggest you to studying chapter 6 of “An Introduction to Computational Fluid Dynamics - Versteeg”.
It is very good.
mhm is offline   Reply With Quote
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 17:02
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver renyun0511 OpenFOAM Running, Solving & CFD 0 November 10, 2010 01:47
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
SIMPLE algorithm Jonathan Castro Main CFD Forum 3 December 10, 1999 04:59
