what should i know if i want to design cfd
Old   October 1, 2002, 08:13
Default what should i know if i want to design cfd
cornerstone
I'm going to be a postgraduated student in intake field and i think i will do a lot of work in cfd. what should i know if i want to design cfd software by myself? and can u give me some advice on which book will help me ?
Old   October 2, 2002, 14:19
Default Re: what should i know if i want to design cfd
JONGDAE KIM
1. What is your thesis topic?
2. Compressible or incompressible flow?
3. High or Low Reynolds number flow?
4. Internal or external flow?
5. Temperature or other scalar values are necessary?
6. What kind of computer can you use?
7. How long time can you afford on your thesis?
8. Are you familiar with coding work?
9. What about the previsous works done by your colleagues?
Please specify your objectives and your situations, not only myself, but also other experts on the CFD field can give you information.
Kim.
Old   October 2, 2002, 15:45
Karl
You also want to focus on what is going to be your contribution to Research.
Re-writting a CFD code from scratch might be interesting to learn what it is, but not novel per se. Sometime a tinier application started/developped from existing techniques/codes might be more valuable from a science and (practical) engineering point of view. As my supervisor used to say: "No need to re-invent the wheel".
It meiht also be more valuable for an employment/career viewpoint as it will have taught you to develop some method and/or code but also to lead something more along the lines of an engineering consultancy...
This is of course an open advice and I do not prtend it to be the Truth! Good luck!
Old   October 4, 2002, 08:37
joel
you might as well ask how long is a piece of string
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
CFD in a nutshell CFD Dummy Main CFD Forum 34 July 8, 2000 00:29
Errors in CFD Lily Kabanj FLUENT 8 May 1, 2000 07:52
goal of CFD MYM,Rameez Main CFD Forum 7 August 16, 1999 00:12
CFD Symposium (Call for Papers) Chris R. Kleijn Main CFD Forum 0 October 5, 1998 10:25
