implementing Wall Laws
Old   November 8, 2002, 09:44
Default implementing Wall Laws
stephen
At present I am implementing the standard universal Log law into a research CFD code. The question is " is the slip velocity imposed purely as a tangential component to the boundary or is there still a normal velocity component?" Cheers Stephen
Old   November 12, 2002, 11:26
Default Re: implementing Wall Laws
AMV
can u explain what u mean to say
Old   November 13, 2002, 09:58
stephen
I'll try to explain my question again:
Taking a flat plate as an example with x being in the streamwise direction and y is normal to the plate. Is the Slip Velocity i.e. u+ imposed on the element adjacent to the boundary, purely in the x direction or does it have y compentant as well?
The turbulence model being used is KE model. And Wall function is the Standard unverisal log law.
My knowledge tells me that it should only be implied in the x direction, but Iam just seeking reasurance. If this still doesn't make sence I will try again.
Cheers
Stephen
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
UDF to Access Wall Normal Concentration Gradient Daniel Tanner Fluent UDF and Scheme Programming 4 February 18, 2015 14:35
Tomiyama wall lubrication force Edy OpenFOAM 10 December 13, 2010 11:41
Wall functions tutlhino OpenFOAM Pre-Processing 0 July 2, 2007 05:04
Deal with wall boundary with moving mesh by FVM? aiya Main CFD Forum 6 May 10, 2007 11:33
