February 14, 2003, 08:08 |
boundary layers and k-w model
I'm trying to create a compressible turbulent boundary layer profile to fit experimental data from a supersonic flat plate test case. The reason I need an analytical profile is to act as an inlet to the computational domain, as the experimental data doesn't go into the viscous sublayer. I am using the Wilcox k-w turbulence model so therefore require profiles not only for the velocity, temperature, density etc.. but also for the k (turbulent kinetic energy) and omega (specific dissipation rate) from the viscous sublayer through to the boundary layer edge. The velocity, temperature and density profiles seem okay but I am having trouble finding references on how to specify the k and omega profiles for compressible flat plate cases. I'd have thought that this is something turbulence modellers do on a regular basis so can any of you guys let me know of any good references that specify exactly how to create the k and omega throughout the whole boundary layer. (I have the Wilcox book) or alternatively what you turbulence modellers usually use in a case like this. Also, can anybody tell me what Wilcox uses to create the initial boundary layer profile in the EDDYBL code? Thanks in advance for any help and advice Paul |
December 8, 2009, 02:01 |
EDDYBL code
Rungroj W.
Hi paul
Do you have EDDYBL code? Can you send it to me via e-mail? Thank you in advance. Sammy |
Boundary layers in Gambit | Ian | FLUENT | 3 | March 3, 2012 09:54 |
High-Re / Boundary Layers | alex_rubel | OpenFOAM Running, Solving & CFD | 0 | March 30, 2011 23:26 |
SST model and boundary layers | Rodrigo Basniak | CFX | 7 | March 27, 2008 14:19 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
Gambit 2 Boundary Layers | An Modh Coinniolach | FLUENT | 2 | January 30, 2002 11:54 |
