March 4, 1999, 00:09 |
Hardware for CFD
Dear Sirs, I am an architect concerned with energy efficient building, and I am beginning studying CFD. I intend to use it for investigation on natural ventilation systems. I would like to know what would be the minimum hardware required to start with CFD, and what would be a mid-suitable to enable some further research. Please any suggestions are welcome. Thank you,
Santiago L. Torres tiago@sminter.com.ar |
March 4, 1999, 04:32 |
Re: Hardware for CFD
The hardware really depends on the size of the model you wish to generate. A basic guide is the following; Meshing / Grid Generation - 64 Megs of RAM per million cells (based on ICEM CFD HEXA/TETRA) Solving - 1 Gig of RAM per million cells Storage - as much hard disk space as you can afford (most CFD users on this list will know of storage problems!) The type of machine really depends on your budget, I always use Silicon Graphics but HPs and SUNS may be worth looking at. regards Dave Minns |
March 4, 1999, 12:44 |
I agree completely with Dave, just want to add cpu speed is a direct function of your patience and problem size, i.e. get the fastest you can afford. We run SGI's as well and their prices are dropping... Good luck, Erich |
March 4, 1999, 21:52 |
200,000 cells are definitely enough for my object, so I wonder if I can run CFD in a PC with an acceptable speed, if so, what is the requirement for harddrive, RAM for best performance? Thanks for you experts.
March 5, 1999, 07:58 |
I hope this information may help:
it is possible to reach the solution of 12 dependent variables using total 200 000 control volumes for a complete modeling of a furnace with Pentium Pro processor,256 Mb RAM, 2 CPU on Windows NT and run 3 differentcase at the same time. N. Kayakol |
March 6, 1999, 17:57 |
My advice is to research the available software packages that would be able to generate solutions to your satisfaction and then purchase the hardware required. I you are lucky, you may find a package that can run on your PC with little or no upgrading. I believe FLOVENT from Flomerics is specifically tailored for ventilation simulations in buildings. I suggest that you start by talking with an engineer there to see if they can meet your needs.
March 7, 1999, 20:08 |
Thank you for your answers. They've been great help!
S. L. Torres |
March 25, 1999, 15:19 |
For a 2-D RANS using the Spalart-Allaras(sp?)turb model with 20,000 grid points, a PC with 450Mhz cpu, take about 15mins for 3000 iterations.
Hardware for running ANSYS Fluent 12.1 | ngj_22 | Hardware | 2 | September 29, 2010 07:26 |
Hardware recommendation? AMD X2, Phenom, Core2Duo, Quadcore? | rparks | OpenFOAM | 0 | April 22, 2009 09:10 |
Hardware Recommendation for Parallel Processing | Brian Bian | CFX | 2 | February 7, 2006 17:27 |
hardware | Guus Jacobs | Main CFD Forum | 24 | May 3, 2000 16:42 |
CFD hardware requirements | Jayprakash | Main CFD Forum | 1 | February 1, 2000 18:24 |
