Question about QUICK at boundaries
Old   June 7, 2003, 00:01
Default Question about QUICK at boundaries
CFDRookie
I'm looking in page 128 of "An Introduction to Computational Fluid Dynamics" by Versteeg and Malalasekra copyrighted in 1995. In the example problem (1-D, convection-diffusion) illustrating QUICK, I have a problem deriving the far RHS term of Eqn. 5.54.
More specifically, how do I go from one form of the DIFFUSIVE FLUX THROUGH THE WEST BOUNDARY, D_A (#_P - #_A), to the following form {D_A [ 9(#_P) – 8(#_A) - #_E ] } / 3 .
where D_A = diffusion coefficient at west boundary; _A = at west boundary; _P = at central node; _E = at east node; _0 = at mirror node; # = transported property;
If anybody could answer this before I go to the paper by Leonard (1979), that would be greatly appreciated. I already understand how the mirror node works and how the value of the transported property at the mirror node is: #_0 = 2(#_A) - #_P .
Thanks!
Old   June 7, 2003, 12:15
Default Re: Question about QUICK at boundaries
Mac
If I understand your question, this has nothing to do with QUICK, which is for the convective terms. The simple form of the diffusive flux at the boundary produces a zeroth order truncation error for the diffusion term div(D grad #), but the second and more complicated form is first order. You can verify this by the usual Taylor series expansion of the difference equations. Your expression for #_0 leads to the inaccurate form of the diffusion term. The expression for #_0 corresponding to the first order diffusion term has a term proportional to #_E. The algebra is straightforward.
Old   June 7, 2003, 12:36
CFDRookie
Thanks, that's the answer I was looking for. And yes, I had a brain freeze, I should not have even mentioned QUICK which as you mentioned relates to convective terms.
Quick UDS question lholsen08 FLUENT 10 September 26, 2011 16:21
Problemas with Quick titio OpenFOAM Running, Solving & CFD 4 May 12, 2010 06:09
Periodic Boundaries in GAMBIT!! swetha FLUENT 1 November 26, 2006 22:02
Quick question on data export - please help Riaan FLUENT 0 June 12, 2006 12:24
Quick and easy QUESTION Freeman FLUENT 0 December 9, 2005 17:39
