June 20, 2012, 09:34 |
code request
#21 |
Hi everyone,
Can someone please send me the matlab code as well? - sjd1e11@soton.ac.uk. Many Thanks, Steven |
August 21, 2012, 06:45 |
#22 |
Martin Söder
I would also be interested in the code, and would be very thankful if I could get it martins@mech.kth.se /Martin |
November 1, 2012, 00:15 |
turbulence spectrum
#23 |
hi,
i'm doing my undergrad final year prjct on simulation of atmospheric boundary layer in wind tunnel.....have to measure wind profile, turbulence intensities and turbulence spectrum.... can anybody help with the turbulence spectrum....what i need to measure...how to get the plot? thank you in advance |
November 2, 2012, 08:53 |
#24 |
Kevii
wow aye
doing spectum always does my head in everytime :\ i suck at this T__T |
February 8, 2013, 16:20 |
Autocorrelation Function help
#25 |
Kealie Goodwin
I am also trying to compute the turbulence energy spectrum for some velocity data I have.
My data are taken with a profiling ADV so I have u, v, w velocities for 12 points along a depth profile. These data are collected over time, which is used for a x-space proxy. In short, I have u, v, w velocity data spatially distributed across x and z dimensions (only one point in y-direction). So, 3 matrices that are 1501 (x) by 12 (z), one each for u, v, w. I understand all the steps of calculating the energy spectrum. My only problem is that I'm not sure I completely understand the autocorrelation step in Pope, especially with respect to my data. R_ij(r, x) = <u_i(x) u_j(x+r)> The <> notation is an average, correct? What does this mean for a scalar? Or is this the dot product notation? Again what does this mean for a scalar? If anyone has any matlab code for this portion that they are willing to share, it would be helpful. Thanks! |
February 9, 2013, 04:01 |
#26 |
Filippo Maria Denaro
Rep Power: 71 |
just consider a 3d Cartesian mesh and (j,k) some fixed positions. This is some lines of my Matlab code for the energy spectrum
% ____________ E_uu (stream-wise)______________ % ff is a dump array for using the FFT of the field u(i,j,k) for i = 1:np+1, ff(i) = u(i,j,k); end % Discrete transform: computation of the Fourier coefficient c=fft(ff,np); for q = 1:np, c(q)=c(q)/np; end % Computation of the modulus squared. Cycle for all the wavenumbers for q=1:np, cu(q,k)=c(q)*conj(c(q)); end Then, you must simply plot your power spectrum. Generally, the computed spectrum are also computed along the whole homogeneous directions (e.g. for all the k) and then averaged to have a statistically meaning. |
February 12, 2013, 12:30 |
#27 |
Kealie Goodwin
Thank you for your code, FMDenaro. However, it's difficult for me to understand your process without your data. Does anyone have the math formulas they used for the autocorrelation? Again, the steps I'm using are:
1. Calculate autocorrelation to get signal into wave number space 2. Take fft 3. Calculate energy E(k) = E(k) + abs(V(i,j,m))^2 + abs(U(i,j,m))^2 + abs(W(i,j,m))^2; 4. plot energy vs wave number |
March 23, 2013, 21:54 |
#28 |
ehk
modes should change from -N/2:N/2.
May 4, 2013, 12:30 |
#29 |
Bobby
Dear FMDenaro
Thanks for sharing ur code. Last edited by babakflame; May 4, 2013 at 12:50. |
May 28, 2013, 09:55 |
The code
#30 |
martin lindström
Can you please send me the code as well? martinrjl@gmail.com
Thank you in advance! |
June 20, 2013, 16:07 |
#31 |
Rep Power: 12 |
If somebody can share the code for energy spectrum calculation I would greatly appreciate that. My email is: alexbn024@gmail.com
July 10, 2013, 16:07 |
#32 |
Nik
Can you send me the matlab code as well please? Thank you very much. My email is nikthomar@gmail.com.
September 6, 2013, 04:56 |
#33 |
Terrence Nguyen
Can anyone also send me the matlab code for the energy spectrum calculation, please??
My email is: sonnyvo018@yahoo.de |
September 6, 2013, 06:37 |
#34 |
Rep Power: 71 |
there is nothing else to do that loading the data in matlab, calling the built-in FFT and plotting the modulus of the Fourier coefficients versus the frequencies
November 4, 2013, 12:17 |
#35 |
Arne
Rep Power: 12 |
November 6, 2013, 16:32 |
#36 |
cfdnewbie
Rep Power: 20 |
The question has been answered in the posts above by FMDenaro, including the code! It is 3 lines in Matlab, that should be doable...
December 4, 2013, 03:06 |
#37 |
Christian
Hi Everyone,
I am currently trying to perform a problem similar to this one except with a different geometry. Could someone please forward me the matlab code harish sent? My email is combustion.spot@gmail.com Thank you in advance |
January 16, 2014, 07:51 |
#38 |
S.Bogoda
Could somebody pls send me the matlab code? sakurabogoda@gmail.com |
March 24, 2014, 01:38 |
code for energy spectra
#39 |
chandra shekhar pant
Can anyone send the code for energy spectra to me also. chandukec@gmail.com
It will be a great help. Thanks in advance |
April 20, 2014, 21:40 |
#40 | |
Huang Xianbei
I think the third line should be: cu(q)=c(q)*conj(c(q)) As known, the velocity spectrum tensor is phi[i,j](k)=cu(k),the energy spectrum is integrated to E(k)=1/2*cu(k)*dS(k) where S(k) is the sphere's surface area with radius mag(k) is this means to calculate E(k)=1/2*cu(k)*4*pi*k^2? |
energy spectrum, fft |
turbulent energy spectrum problem | cfd.newbie | Main CFD Forum | 6 | September 24, 2015 16:13 |
turbulent energy spectrum | cfd.newbie | Siemens | 1 | June 19, 2008 23:48 |
turbulent energy spectrum | cfd.newbie | FLUENT | 0 | June 18, 2008 18:34 |
LES correlation and turbulent energy spectrum | Fabian | Main CFD Forum | 4 | October 18, 2005 02:04 |
Energy Spectrum | Emad Khalifa | Main CFD Forum | 3 | June 30, 2003 16:03 |
