fully developed velocity profile in 3D
Old   July 27, 2003, 05:00
Default fully developed velocity profile in 3D
S.S.
I have a laminar, viscous 3D flow in a duct (brick type geometry) with rectangular cross-section. I want to use velocity inlet and pressure outlet boundary conditions. There is a nice expression for fully-developed velocity profile (parabola) in 2D (written in terms of u_max). How is it written in 3D? Any help or reference will be highly appreciated. Thanks in anticipation.
Old   July 27, 2003, 15:12
Default BC at the inlet of the tube
Jackie
I've had a problem of specifying the boundary condition at the inlet of an opened-end tube. I use CFD to simulate flow inside the tube having an embedded momentum source. The momentum source is located at the center of the horizontal tube and both ends (inlet and outlet) of the tube is opened to the atmosphere.
I specify zero static pressure at the outlet (reference to ambient). The flow inside the tube is driven by the given momentum source. However, I don't know what the boundary condition at the inlet of the tube should be.
Could anybody please give me some suggestion?
Thank you very much
Jackie
Old   July 27, 2003, 16:00
Default Re: BC at the inlet of the tube
xueying
B.C. at inlet might be fully developed, i.e. \vec{n} \cdot \nabla \vec{v} = \vec{0} (in latex form).
Old   July 27, 2003, 16:05
Default Re: fully developed velocity profile in 3D
xueying
The fully developed flow velocity profile for a rectangular channel is a serial solution; following is the analytical solution written in latex form:
u(x,y) = \sum_{n=1}^{\infty} u_n(y) \phi_n(x) \] where \[
u_n(y) = \frac{a_n}{\lambda_n} \left( -1+\frac{sinh\sqrt{\lambda_n}y+sinh\sqrt{\lambda_n} (b-y)}{sinh\sqrt{\lambda_n}b}\right) \]
\phi_n(x) = \sqrt{\frac{2}{a}}sin(\frac{n \pi x}{a}), \;\; n=1,2,... \]
where $a$ is the length in the $x$ direction, $b$ is the length in the $y$ direction, $\lambda_n = \frac{n^2\pi^2}{a^2}$, $a_n = \sqrt{\frac{2}{a}}\alpha \frac{a}{n\pi}[(-1)^n-1] $ and $\alpha = - \Delta p/(L\mu)$, $\Delta p$ is pressure drop in the $z$ direction with length $L$, and flow viscosity $\mu$.
Old   July 27, 2003, 16:47
S.S.
Yes, but can it be expressed in terms of u_max (maximum velocity)? In 2-D, there is a nice relation for u(y) which is given in terms of u_max (maximum velocity which occurs at the centerline of the parabola), and the y-coordinates. This expression is very convenient to use as velocity inlet b.c. profile in CFD codes (provided that u_max is known). Is there anything like that in 3D?
Also, can someone give me a reference where the detailed derivation of this exact 3D solution can be found?
Thanks.
Old   July 27, 2003, 23:07
Hall
If u have a nice expression for fully-developed velocity profile (parabola) in 2D, I think it is easy to expand it to 3d, just let the profile rotate around the longitude axis
let's say if x is the longitude axis, and at the inlet, u = U(y) is a function of y. Now at 3-D, again you set the x' as longitude axis. At inlet, you will have coordinates like (y',z'), take r = sqrt(y'^2 + z'^2), and let u = U(r). Now, u expand the 2-d velocity field to 3-d
Old   July 29, 2003, 12:02
xueying
The detailed derivation of this exact 3D solution can be found in book titled as Mathematical Methods in Chemical Engineering; the authors are: Varma, A. & Morbidelli, M.; Oxford University Press, New York Oxford, page 494.
Old   July 6, 2013, 15:36
Ugur Goktolga
mugurg is on a distinguished road
I know it has been decade since this thread was opened, but just in case somebody googles and finds this page, I wanted to help.
You can check the equations 335-338 from Shah and London. Generating parabolic velocity profile for 3D flows might not be a good idea since it does not represent fully developed flow for especially high aspect ratio channels. So, better check the equations that I have written. Actually, I have written a MATLAB script that generates fully developed velocity profile for rectangular channels and uploaded it to MATLAB file exchange forums, but it is not approved yet. If somebody replies this thread, I can supply the link for the file, or send as an attachment.
mugurg is offline   Reply With Quote
Old   January 10, 2017, 00:48
Default fully developed profile at the inlet of a duct of rectangular section
vidyadhar
vidyadhar is on a distinguished road
Hello Ugur,
I have seen this thread more than a decade after you have posted it.
I want to have fully developed velocity profile at the inlet of a duct with rectangular cross section.
I request you to help me in executing the same.
Thank you,
vidyadhar
vidyadhar is offline   Reply With Quote
Old   January 10, 2017, 01:23
Lane Carasik
lcarasik is on a distinguished road
Originally Posted by vidyadhar View Post
Hello Ugur,
Thank you,
vidyadhar
The matlab script in question: https://www.mathworks.com/matlabcent...tangular-ducts
lcarasik is offline   Reply With Quote
Old   January 11, 2017, 12:39
Default Equation used to generate fully developed profile in the rectangular duct
  #11
vidyadhar
Originally Posted by lcarasik View Post
Dear Lane Carasik,
Thank you for the quick reply.
I have seen the code provided in the link.
May I request you to please let me know the equation used in the code.Also, what is um in the equation given. Though the reference mentioned in the code is a book by Shah and London, I am unable to access it.
Thanks & Regards,
Vidyadhar
Old   January 11, 2017, 12:44
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Dear Lane Carasik,
Thanks & Regards,
Vidyadhar
the solution for a laminar steady developed flow in a rectangular duct satisfies the Poisson equation Lap u = Re*dp/dx with u=0 on the boundaries.
FMDenaro is offline   Reply With Quote
Old   January 11, 2017, 12:49
vidyadhar
Hello Filippo Maria Denaro,
Thank you for the reply.
Since there are many analytical expressions available in various sources for the Poisson equation, I would like to know which form was used by the coder to develop the code.
I request you to please let me know the same.
Thanks & Regards,
vidyadhar
Old   January 11, 2017, 13:00
https://books.google.it/books?hl=it&...20duct&f=false
Old   January 11, 2017, 13:06
vidyadhar
Thank you.
I will try to find the equation in the book, if it is not hidden.
Regards,
vidyadhar
time dependent BC with fully developed velocity profile susheil FLUENT 6 December 20, 2012 05:41
Fully Developed Flow in Star-cd SMM STAR-CD 0 September 5, 2011 22:08
Fully developed flow profile icfd Main CFD Forum 3 May 20, 2009 22:21
fully developed velocity profile KS FLUENT 1 November 12, 2008 08:36
inlet velocity profile for fully developed turbule pankaj saha Main CFD Forum 4 August 24, 2007 16:53
