June 14, 2009, 02:17 |
Which version of Linux is better?
Rep Power: 16 |
As we all know, there are many versions of Linux, every of which has their own features such as good stability, high efficiency. I am a jackaroo of using Linux, and have no experience in it. And I want compile OpenFoam and use it on Linux plateform, so I wonder which version of Linux is more suitable for me?
June 14, 2009, 06:00 |
Fernando Herrera
Rep Power: 17 |
All the linux distributions will offer you the same basic experience. If you are new to the linux word, try ubuntu. It is easy to install and it has a very good community. They even explain how to install openFOAM (process that is not difficult at all) in your brand new box.
Once you feel more confident with linux, try something more interesting, like Arch. But, this is not a linux forum, so, have a look at other sites, you can get more educated reasons for using a specific distribution. |
June 14, 2009, 06:58 |
andy
Rep Power: 18 |
If you only want to compile one program and then go back to Windows then the distribution does not matter. Use whatever your neighbour is using since this is likely to be the quickest way to get going.
The version will matter if you want to use Linux as a platform for your future work because this will require you to invest your time learning how to get things done. In this respect the versions of Linux differ signficiantly but things are reasonably clear if you are an educated user (i.e. one that has invested time to understand how the main parts of the system work and looks things up in manuals) looking for a stable platform to run the programs that are important to you. This describes most CFD developers although not necessarily most CFD users. |
June 14, 2009, 16:39 |
N/A
Rep Power: 17 |
I have successfully compiled OpenFOAM on Ubutunu, Fedora, and LinuxMint. The version of linux you use does not really matter for OpenFOAM. If you are also interested in using GUI for regular work, I would suggested using Ubuntu or Suse.
June 16, 2009, 04:05 |
andy
Rep Power: 18 |
I seem to have deleted naming the choice of Linux platform for CFD work which went when I abandoned my summary of the 3 main flavours. The most widely used and most stable Linux platform for scientific computing is RHEL/Centos/ScientificLinux (all effectively the same code base but with differing support). It is the stability, type of support and dominance in the commercial and scientific fields which makes it the default choice rather than anything related to technical ability.
Of course, there may be good reasons for adopting another distribution (e.g. your department uses Debian/Ubuntu and it is the distribution the computer administrator knows) but for someone on their own looking for a stable platform for CFD it is the conservative choice. |
June 17, 2009, 08:56 |
Rep Power: 17 |
My suggestion is that you go to http://distrowatch.com/ and pick the most used distro (which will be Ubuntu). Why? Well if you are new to linux it is always nice to have a large community to help you through all problems that you will encounter. As you learn a bit more you can change distro and still use the same community support.
"Trying is the first step to failure." - Homer Simpson |
June 18, 2009, 17:16 |
HP Kritzinger
Rep Power: 17 |
OpenFoam is traditionally built on Suse platforms. There are many people using it on Ubuntu as well.
If you have any Linux distros and people with experience around you, pick what they are using. You can also try the caelinux distro. This is a Linux version with many opensource CAE packages allready built into the distro. on the web at http://www.caelinux.com |
June 18, 2009, 19:32 |
#8 | |
Ahmed
Rep Power: 18 |
The difference between the free and paid is simple, the free is the testing ground for the paid. It has been mentioned before that OpenFoam can be installed on different distros, personally I have the free Open Foam 32 bits installed on Debian Lenny and Open Suse and based on my own experience, I prefer the debian installation over the Open Suse OK, so you have to be more specific and clear when asking this question First decide what are you lookin for ? 1- Free Open Foam or Paid Open Foam then 2- Free Linux or paid Linux Google for mor e information and good luck |
Which Linux version best for OpenFOAM? | yewebis | OpenFOAM | 7 | June 10, 2009 06:31 |
Loading Fluent Sover and Gambit on LINUX 9 version | Kiran | FLUENT | 0 | October 11, 2007 01:26 |
Running Fluent on Red Hat Linux WS version 4 | Bob | FLUENT | 1 | September 4, 2005 05:01 |
Can't export TecPlot files from Linux version | Dan Brzozowski | FLUENT | 0 | August 4, 2004 22:08 |
Which version of Red Hat Linux for Fluent 5.4??? | Steve Howell | FLUENT | 6 | August 22, 2001 09:49 |
