Help needed for meshing the following geometry... |
June 23, 2009, 16:38 |
eers
Rep Power: 17 |
Hi all
I am bit new to gambit n i need to do meshing for the following component as much refined as possible..I tried to do submap meshing by specifying vortex type but couldn't succeed..please suggest me for nice mesh... eers Last edited by eers; July 8, 2009 at 14:23. |
June 24, 2009, 00:20 |
Daniel Langmayr
Rep Power: 17 |
i would split the geometry in several connected rectangels. each of these newly generated rectangles can be meshed with the mapped scheme in gambit. i think this should work for your geometry.
good luck |
June 25, 2009, 01:34 |
Daniel Langmayr
Rep Power: 17 |
i am not sure if i understand what you mean.
at the moment you should have just one face in your gambit model. this one face should be split with the split face command. I would use the option split with "Faces (Real)" and the option "connected" enabled. Hope this helps. |
June 25, 2009, 08:16 |
Andrew
Rep Power: 18 |
Did you mesh the edges first? What is wrong with the mesh that you show? If you mesh the edges first and then mesh the face it might give you what you are looking for. You can try different counts on the edges too.
June 25, 2009, 15:33 |
eers
Rep Power: 17 |
thanx xdanielx & nettler...I did the way u said but it's coming out to be with lot many skewed elements...The resulting mesh is given below..
June 25, 2009, 18:47 |
N/A
Rep Power: 17 |
Is it mandatory that you need to use block structured meshes for your domain? You can try using unstructured/hybrid meshes otherwise. It might be a bit of trial and error to get good block structured meshes for the geometry as there are many sharp corners.
June 26, 2009, 00:13 |
#9 |
Daniel Langmayr
Rep Power: 17 |
i would try to seperate the geometry as shown in the attachment. this is just a first shot to play around and there are different approaches as stated by others...
good luck |
June 26, 2009, 17:02 |
#11 |
eers
Rep Power: 17 |
As i divided the geometry, i have left with inner edges which makes an error "continuum entity fluid path doesn't contain any valid entity and is not written"..I 'll appreciate for your help...
Regards eers Last edited by eers; June 29, 2009 at 15:28. |
June 29, 2009, 15:29 |
#12 |
eers
Rep Power: 17 |
Regards eers |
meshing a 2d |
Importing CAD geometry and Editing edges to match | Ahmed | CFX | 15 | March 21, 2016 12:39 |
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry | villier | OpenFOAM Meshing & Mesh Conversion | 17 | June 15, 2010 19:51 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
Consultant needed to optimize an oblique diffuser. | Paul | Main CFD Forum | 0 | March 24, 2004 16:59 |
Input Geometry from Ideas to Gambit | Knick | FLUENT | 2 | December 11, 2002 03:59 |
