divergence with higher order scheme
Old   July 23, 2009, 08:19
Default divergence with higher order scheme
Chandra
shekharc is on a distinguished road
I am doing DNS and am in process of implementing higher order schemes. I am done with implementing it in momentum equation etc.
However, when it comes to calculate divergence in a cell, i.e. Div = du/dx+dv/dy+dw/dz, I am getting a bit confused whether I should implement higher order scheme here as well or I should keep it just second order accurate.
I am asking it because if 2nd order accurate,
du/dx = (u[i+1]-u[i])/(x[i+1]-x[i]) etc. on staggered grids. It gives a feeling of the rate of mass accumulation in the cell, a physically meaningful quantity.
However, if we change this to 4th order discretization,
du/dx = f(u[i+2], u[i+1], u[i], u[i-1]) etc. which doesn't look like giving mass accumulation in the cell in discrete manner.
Could anyone please point out which one should be preferred?
Thanks!
shekharc is offline   Reply With Quote
Old   July 23, 2009, 13:53
RenardP is on a distinguished road
Usually you should keep the same order of discretization on all spatial derivatives if you want to have a pure 4 order scheme let's say. Otherwise your DNS will be only 2nd order.
RenardP is offline   Reply With Quote
divergence, higher order
Higher order terms in the equations Argyle Main CFD Forum 7 October 31, 2008 07:41
CFL condition for higher order schemes Shyam Main CFD Forum 2 February 14, 2008 14:24
Higher order downwind scheme jelmer OpenFOAM Running, Solving & CFD 4 August 9, 2006 06:43
Higher order discretization on staggered grid Chandra Shekhar Main CFD Forum 9 January 27, 2005 16:31
Discretisation scheme in CFX-1st or 2nd order? Pete CFX 10 January 12, 2005 12:48
