Can CFD Simulate this device?
Old   September 6, 2009, 10:48
Default Can CFD Simulate this device?
Karl
leviterande is on a distinguished road
Hi everyone, I am working on a device called the Vortex Thruster.
This prototype-propulsion-device is composed of:
1. A vortex chamber: a centrifugal impeller which is located in a bottom of a cylinder.
2. A diffuser: an upward lifting donut shaped airfoil, that is mounted above the vortex chamber.
3. A source of pressurized air: a high pressurized air that is delivered to the impeller from the bottom.
The principle is this: as the impeller spins, air is pushed to the wall of the vortex chamber and swirls upwards and along over the airfoil diffuser and creating a low pressure on the diffuser. Thus lift/thrust is produced.
What I am wondering is if Fluent CFD or other is capable of calculating/simulating the following:
1. The incoming and outgoing swirling airflow to and from the impeller and device.
2. Showing the low pressure zones , on the diffuser
3. Calculating the thrust/lift vs the power required.
You can see an animation where the device is shown and the airflow is shown.
(I dont know if one can post pics of the model. I tried but I couldnt here?)
http://www.youtube.com/watch?v=0oHqkgWEcRY
Best Regards
/Karl
leviterande is offline   Reply With Quote
Old   September 6, 2009, 16:44
otd
private
otd is on a distinguished road
I'd guess that any compressible CFD code that will do axisymmetric (rotating) flow - that's u, v, w as functions of r and z but with no variation with angle - can produce a steady-state axisymmetric flow field from which you could calculate the appropriate surface integrals for lift (thrust) etc. Probably any realistic value of throughput would require a turbulence model as well.
Please note this is a GUESS.
otd is offline   Reply With Quote
Old   September 7, 2009, 09:51
Ahmed
Ahmed is on a distinguished road
Best Regards
/Karl
When posting, scroll down the page till you see the additional options, there you find a button to manage your attachments. Good Luck
You see, I prefer not to connect to youtube and similar sites (just a security rule)
Ahmed is offline   Reply With Quote
vortex thruster
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
CFD of Subsea Well Intervention Device Dash Swift Main CFD Forum 1 April 17, 2006 14:09
STAR-Works : Mainstream CAD with CFD CD adapco Group Marketing Siemens 0 February 13, 2002 12:23
ASME CFD Symposium, Atlanta, 22-26 July 2001 Chris R. Kleijn Main CFD Forum 0 August 1, 2000 10:07
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
