Meshing a curved surface with orthogonale lines. |
April 2, 1999, 04:02 |
Hy everybody, does anuyone know a method for generating a orthogonal mesh on a 3D curved surface. Thanks.
April 2, 1999, 12:48 |
Re: Meshing a curved surface with orthogonale lines.
3D orthogonal coordinate systems do not exist in general. That is, your curved surface cannot, in general, be a constant coordinate surface of a 3D orthogonal coordinate system (although it can if your surface curves in only one direction?).
This raises two questions: where does the requirement for orthogonality come from? and what mathematical properties are actually required in the curved grid. Devising a method that directly seeks to minimise the required numerical property would seem the optimum way forward. One simple approach to generating a reasonably "orthogonal" grid would be to solve the 2D orthogonal generating equations via projection onto the surface and evaluating the scale factors with 3D distances. I can think of a couple more approaches but hesitate to make a firm recommendation without having done it. |
April 2, 1999, 18:21 |
Actually, this has been done before by using Poisson equations for the grid lines. A description of this can be found in "A Fast Method for the Elliptic Generation of Three-Dimensional Grids with Full Boundary Control" by A. Hilgenstock. This was published in 'Proceeedings of the Numerical Grid Generation in Comp. Fluid Dynamics Conference', edited by S. Sengupta, 1988. A briefer description can also be found in "Numerical Methods for Engineers and Scientists", by J.D. Hoffman, McGraw-Hill, 1992.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Surface Repair for Meshing | Andy R | Main CFD Forum | 13 | May 3, 2008 14:33 |
flow rate through curved surface | john | Siemens | 0 | February 13, 2004 01:01 |
Patran Volume Meshing | Deb | CFX | 19 | April 17, 2003 10:56 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
