breakage of liquid stream
Old   October 2, 2009, 14:25
Default breakage of liquid stream
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Dear CFD experts:
I am working on a case involves liquid jet. Reynolds' # is only about 1. nozzle diameter is less than 1 mm, the average speed is around 1.5 m/s. The liquid stram flows downward. In the experiments, the lqiud stream stay intact, say for about 5 cm, then, starts breaking into drops. However, in my CFD results, the liquid stream started breaking at around 2 cm. In CFD, the liquid stream also showed some in-stabiltiy (swing side to side), while I did not observe this in the experiment.
I have played with different surface tension, different schemes (upwind, limitedLinear..) without much improvements.
It will be appreciated if someone can point to me some literatures on break-ups of liquid stream or make suggestions on how to improve my CFD results.
phsieh2005
phsieh2005 is offline   Reply With Quote
Old   October 5, 2009, 12:57
Default Liquid jet disintegration
CFDtoy
CFDtoy is on a distinguished road
Ok. So - here we have a problem of rayleigh instability. For your case - check the viscosity of the liquid (increase it to delay breakup). No problems with surf tension - keep that constant (water - 0.072 etc) The surface tension togehter with viscosity will define droplet diameter and nature of breakup.
this should be straightforward to get good results. Your results are off by more than 50% - Again ! check the fluid properties.
CFDtoy
Originally Posted by phsieh2005 View Post
Dear CFD experts:
phsieh2005
CFDtoy is offline   Reply With Quote
Old   October 5, 2009, 15:19
Pei-Ying Hsieh
Thanks CFDtoy!
I will give it a try.
phsieh
Old   October 5, 2009, 15:22
Default jet breakup
CFDtoy
by the way, i am assuming that you did try different meshes as well. Also, what software or code are you using and the nature of VOF scheme?
/CFDtoy
Thanks CFDtoy!
phsieh
Old   October 6, 2009, 20:44
Pei-Ying Hsieh
Hi, CFDtoy,
I am using OpenFOAM.
Yesterday, I increased the flow domain by 2 times and now the liquid stream did not break, but, still showed some in-stability. In our experiment, the jet is straight and solid within the length we looked at. Maybe I need to increase the flow domain further. Besides the inlet and nozzle wall, I have atmospheric BC all around.
Pei
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Streamfunction? cain Main CFD Forum 5 July 19, 2012 10:05
radiation of molton liquid metal in enclosure richard CFX 0 April 8, 2008 15:43
Need some help for total liquid fraction linus FLUENT 0 December 19, 2006 03:29
entrainment of droplets from liquid surface Elisabeth A. Hove Siemens 0 October 16, 2002 10:11
