second invariant of rate-of-strain tensor
Like Tree2Likes
  • 1 Post By Chun Min Chew
  • 1 Post By Rami
Old   December 9, 2003, 02:02
Default second invariant of rate-of-strain tensor
Chun Min Chew
The shear, or strain, rate is often calculated based on the square root of the second invariant of rate-of-strain tensor. The tensor itself is made up of all the possible deformation of a fluid element, which includes volumetric and shear deformation. I would like to invite comments from everyone concerning:
1) if this second invariant, in its general definition, includes both the volumetric-rate of deformation and shear-rate of deformation? Or simply shear-rate of deformation alone?
2) the physical meaning of the 'second invariant' of the strain rate tensor. I take it as a way to 'average' all the strain components in the tensor, thus an 'effective' strain rate.
I look forward for your comments.
Cheers.
jotac likes this.
Old   December 9, 2003, 10:04
Default Re: second invariant of rate-of-strain tensor
Rami
<html xmlns="urn:schemas-microsoft-comfficeffice" xmlns:w="urn:schemas-microsoft-comffice:word" xmlns="http://www.w3.org/TR/REC-html40">
<head> <meta http-equiv=Content-Type content="text/html; charset=windows-1255"> <meta name=ProgId content=Word.Document> <meta name=Generator content="Microsoft Word 10"> <meta name=Originator content="Microsoft Word 10"> <link rel=File-List href="invariants_files/filelist.xml"> <title>The origin of the invariants is from tensor analysis: For any tensor Aik, you may wish to find its eigenvalues, corresponding </title> <!--[if gte mso 9]><xml> <w:WordDocument> <w:Zoom>BestFit</w:Zoom> <w:SpellingState>Clean</w:SpellingState> <w:GrammarState>Clean</w:GrammarState> <w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--> <style>
</style> <!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";} </style> <![endif]--> </head>
<body lang=EN-US style='tab-interval:.5in'>
<div class=Section1>
<p class=MsoNormal style='text-align:justify'>Chun Min Chew,<o></o>
<p class=MsoNormal style='text-align:justify'><o>*</o>
<p class=MsoNormal style='text-align:justify'>The origin of the invariants is from tensor analysis: For any tensor <span class=SpellE>A<sub>ik</sub></span>, you may wish to find its <span class=SpellE>eigenvalues</span>, corresponding to the principal components (i.e., the rotation to a coordinate system where <span class=SpellE>A<sub>ik</sub></span> becomes a diagonal matrix).
<p class=MsoNormal style='text-align:justify'>Let us concentrate on symmetric tensor only, such as the stress and strain (or-strain-rate). The <span class=SpellE>eigenvalues</span> (principle <span class=SpellE>componenets</span>), <span style='font-family:Symbol'>l</span>, are found from the characteristic polynomial
<p class=MsoNormal style='margin-left:.5in'>|A-<span style='font-family:Symbol'>l</span>I| = – <span style='font-family:Symbol'>l</span><sup>3</sup> + I<sub>1</sub><span style='font-family:Symbol'> l</span><sup>2</sup> – I<sub>2</sub><span style='font-family:Symbol'> l</span> + I<sub>3</sub> = 0
<p class=MsoNormal style='text-align:justify'><span class=GramE>where</span> the invariants are
<p class=MsoNormal style='margin-left:.5in;text-align:justify'>I<sub>1</sub> = <span class=SpellE>A<sub>kk</sub></span> (i.e. the trace of <span class=SpellE>A<sub>ik</sub></span>)
<p class=MsoNormal style='margin-left:.5in;text-align:justify'>I<sub>2</sub> = ½ (<span class=SpellE>A<sub>ii</sub>A<sub>kk</sub></span> – <span class=SpellE>A<sub>ik</sub>A<sub>ik</sub></span>)
<p class=MsoNormal style='margin-left:.5in;text-align:justify'>I<sub>1</sub> = |<span class=SpellE>A<sub>ik</sub></span><span class=GramE>|(</span>i.e. the determinant of <span class=SpellE>A<sub>ik</sub></span>)
<p class=MsoNormal style='text-align:justify'>If you decompose A to its <span class=SpellE>deviatoric</span> and volumetric parts, say S and v, respectively
<p class=MsoNormal style='margin-left:.5in;text-align:justify'>v = 1/3 <span class=SpellE><span class=GramE>tr</span></span><span class=GramE>(</span>A)
<p class=MsoNormal style='margin-left:.5in;text-align:justify'>S = A -<span class=SpellE><span class=GramE>vI</span></span>
<p class=MsoNormal style='text-align:justify'><span class=GramE>and</span> substitute in the 2<sup>nd</sup> invariant, I2, you will notice it becomes
<p class=MsoNormal style='margin-left:.5in;text-align:justify'>I<sub>2</sub> = –½S<sub>ik</sub>S<sub>ik</sub>
<p class=MsoNormal style='text-align:justify'>i.e., the volumetric part is absent, and only <span class=SpellE>deviatoric</span> components are influencing it.
<p class=MsoNormal style='text-align:justify'>Returning to your question, it is true that the 2<sup>nd</sup> invariant of the strain-rate is independent of the volumetric strain. However, if you consider a <span class=SpellE>uniaxial</span> case, where the only non-zero entry is, say A<sub>11</sub>, there is no shear (but the deviator S is non-zero, having diagonal entries) and<span style='mso-spacerun:yes'>* </span>the result in this case is I<sub>2</sub> = 2/3 a<sup>2</sup>.
<p class=MsoNormal align=center style='text-align:center'>I hope it answers your question,
<p class=MsoNormal align=center style='text-align:center'><span class=SpellE>Rami</span>
</div>
</body>
</html>
Old   December 10, 2003, 02:24
Default Correction...
Rami
<head> <meta http-equiv=Content-Type content="text/html; charset=windows-1255"> <meta name=ProgId content=Word.Document> <meta name=Generator content="Microsoft Word 10"> <meta name=Originator content="Microsoft Word 10"> <link rel=File-List href="invariants-2_files/filelist.xml"> <title>The origin of the invariants is from tensor analysis: For any tensor Aik, you may wish to find its eigenvalues, corresponding </title> <!--[if gte mso 9]><xml> <w:WordDocument> <w:Zoom>BestFit</w:Zoom> <w:SpellingState>Clean</w:SpellingState> <w:GrammarState>Clean</w:GrammarState> <w:Compatibility>
font-size:10.0pt;
<p class=MsoNormal style='margin-top:12.0pt;text-align:justify'>Chun Min Chew,
<p class=MsoNormal style='margin-top:12.0pt;text-align:justify'><span style='color:red'>Sorry, there was a mistake in my former posting, leading to a wrong conclusion. Here is the corrected version.<o></o></span>
<p class=MsoNormal style='margin-top:12.0pt;text-align:justify'>The origin of the invariants is from tensor analysis: For any tensor <span class=SpellE>A<sub>ik</sub></span>, you may wish to find its <span class=SpellE>eigenvalues</span>, corresponding to the principal components (i.e., the rotation to a coordinate system where <span class=SpellE>A<sub>ik</sub></span> becomes a diagonal matrix).
<p class=MsoNormal style='margin-top:12.0pt;text-align:justify'>Let us concentrate on symmetric tensor only, such as the stress and strain (or strain-rate). The <span class=SpellE>eigenvalues</span> (principle <span class=SpellE>componenets</span>), <span style='font-family:Symbol'>l</span>, are found from the characteristic polynomial
<p class=MsoNormal style='margin-top:12.0pt;margin-right:0in;margin-bottom: 0in;margin-left:.5in;margin-bottom:.0001pt'>|A-<span style='font-family: Symbol'>l</span>I| = – <span style='font-family:Symbol'>l</span><sup>3</sup> + I<sub>1</sub><span style='font-family:Symbol'> l</span><sup>2</sup> – I<sub>2</sub><span style='font-family:Symbol'> l</span> + I<sub>3</sub> = 0
<p class=MsoNormal style='margin-top:12.0pt;text-align:justify'><span class=GramE>where</span> the invariants are
<p class=MsoNormal style='margin-top:12.0pt;margin-right:0in;margin-bottom: 0in;margin-left:.5in;margin-bottom:.0001pt;text-align:justify'>I<sub>1</sub> = <span class=SpellE>A<sub>kk</sub></span> (i.e. the trace of <span class=SpellE>A<sub>ik</sub></span>)
<p class=MsoNormal style='margin-top:12.0pt;margin-right:0in;margin-bottom: 0in;margin-left:.5in;margin-bottom:.0001pt;text-align:justify'>I<sub>2</sub> = ½ (<span class=SpellE>A<sub>ii</sub>A<sub>kk</sub></span> – <span class=SpellE>A<sub>ik</sub>A<sub>ik</sub></span>)
<p class=MsoNormal style='margin-top:12.0pt;margin-right:0in;margin-bottom: 0in;margin-left:.5in;margin-bottom:.0001pt;text-align:justify'>I<sub>3</sub> = |<span class=SpellE>A<sub>ik</sub></span>| (i.e. the determinant of <span class=SpellE>A<sub>ik</sub></span>)
<p class=MsoNormal style='margin-top:12.0pt;text-align:justify'>If you decompose A to its <span class=SpellE>deviatoric</span> and volumetric parts, say S and v, respectively
<p class=MsoNormal style='margin-top:12.0pt;margin-right:0in;margin-bottom: 0in;margin-left:.5in;margin-bottom:.0001pt;text-align:justify'>v = 1/3 <span class=SpellE><span class=GramE>tr</span></span><span class=GramE>(</span>A)
<p class=MsoNormal style='margin-top:12.0pt;margin-right:0in;margin-bottom: 0in;margin-left:.5in;margin-bottom:.0001pt;text-align:justify'>S = A -<span class=SpellE><span class=GramE>vI</span></span>
<p class=MsoNormal style='margin-top:12.0pt;text-align:justify'><span class=GramE>and</span> substitute in the 2<sup>nd</sup> invariant, I<sub>2</sub>, you will notice it becomes
<p class=MsoNormal style='margin-top:12.0pt;margin-right:0in;margin-bottom: 0in;margin-left:.5in;margin-bottom:.0001pt;text-align:justify'>I<sub>2</sub> = 3v<sup>2</sup> – ½S<sub>ik</sub>S<sub>ik</sub>
<p class=MsoNormal style='margin-top:12.0pt;text-align:justify'>Therefore, for a pure volumetric tensor (A = <span class=SpellE>vI</span>, and therefore S = 0) we get I<sub>2</sub> = 3v<sup>2</sup>. On the other hand, for pure <span class=SpellE>deviatoric</span> tensor (v=0, A = S), the 2<sup>nd</sup> invariant of course has no contribution from the volumetric part.
<p class=MsoNormal align=center style='margin-top:12.0pt;text-align:center'><span class=SpellE>Rami</span>
</div>
</body>
</html>
holzkiste likes this.
Old   December 10, 2003, 11:34
Default Re: Correction...
Chun Min Chew
So, if the tensor A is decomposed into its deviatoric and volumetric tensors, the 2nd invariant of the deviatoric tensor would not contain the volumetric part; while the 2nd invariant for the volumetric tensor would of course contain the voluemtric part.
Then, from the equation for the 2nd invariant: I2 = ½ (AiiAkk – AikAik), does it imply that for a complete tensor, A, the 2nd invariant will include the contributions from both volumetric and deviatoric (non-volume) part?
Thanks again.
strain rate in UDF Paulina FLUENT 11 November 20, 2014 03:06
strain rate magnitude ahmadbakri STAR-CCM+ 1 June 3, 2010 13:03
About "Shear strain rate" leo1985 CFX 0 April 26, 2008 04:48
Strain rate. MM? Main CFD Forum 1 February 15, 2006 08:55
Rate of Strain Tensor from ANSYS FLOTRAN H Mayer Main CFD Forum 0 June 27, 2005 11:56
