outlet pressure
Old   December 13, 2003, 23:08
Default outlet pressure
grad-student
Can somebody point me to a reference where computational implementation of specified pressure condition at outlet is described..or a code on net where it is programmed..or brief steps...
...do I still specify dv/d(streamwise) =0 to v-equattion solver like in normal outflow condition (zero u v gradient)..
Old   December 14, 2003, 22:02
Default Re: outlet pressure
Keith
As far as I know, if you are working on incompressible fluid, the necessary pressure term is your hydrostatic pressure at the outlet boundary. Correct me if I am wrong, I personally think that the pressure doesn't mater. It is the pressure gradient that drives the flow(go back to fundamental N-S equation). Hope that helps.
keith.
Old   December 15, 2003, 04:47
barbaro
Try this book:
Versteeg and Malalasekera, An Introduction to Computational Fluid Dynamics, pag. 203
Old   December 17, 2003, 23:19
grad
Old   December 20, 2003, 07:09
kenn
once you use partial u and v partial streamline-wise = 0, you should not specified pressure anymore. if you want to use pressure Open boundary conditions, you may have to drop velocity OBC.
because, otherwise OBC you provide may conflict each other, and the discrete system may become highly ill-posed.
Problems in pressure when using mass flow rate outlet rafiktharwat CFX 11 January 2, 2014 17:21
pressure oscillation near pressure outlet boundary kino Main CFD Forum 5 April 13, 2011 11:03
Pressure Outlet setting CoG STAR-CCM+ 4 June 9, 2010 21:47
what actually is the 'zero pressure outlet b. c.' hwe001 CFX 4 June 7, 2010 15:22
Backflow occuring at a pressure outlet? Dave FLUENT 1 August 12, 2004 17:39
