RobT
Rep Power: 16 ![]() |
Starting with a model which has a yPlus less than 9 when a surface is smooth, if I change the surface to 1mm roughness, the y+ increases by a factor of 10. Does this mean that the mesh needs to be refined again to reduce the y+ or does the inevitability of the high y+ reduce the importance?
Basically, has everyone found it to be the case that a low y+ as important with a smooth as a rough model? I assume that the answer's yes, but just wanted to check before increasing simulation time significantly. |
Surface roughness in Flow-3d | Marco | FLOW-3D | 3 | June 3, 2018 02:15 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
