November 7, 2009, 08:13 |
SIMPLEC Method
S.M. Hadi Meshkati
Rep Power: 16 |
Hey everyone,
I try to develop a CFD code by solving 3D Navier-Stocks equations in curvilinear coordinates. But I have a problem with coupling of pressure and velocity (pressure correction equation - p’) that I use SIMPLEC method for it. In initial iterates (that no pressure gradients exists in domain) the momentum equations have no source term and then: ap=sigma(a_neighbors). Therefore the parameter of [ap - sigma(a_neighbors)] that appears in the denominator of SIMPLEC method equals to zero and then the divides by zero error was occurred. What can I do? Thanks for advance. Hadi (Some of my code specifications are: Finite volume method, non -staggered grid, incompressible fluid, steady calculation, no free surface calculation, Rhie and Chow interpolation method, laminar or k-e turbulence model, SIMPLEC pressure correction method and the test case is straight channel with uniform velocity boundary condition in its inlet and if any another comments was needed just tell me) |
November 7, 2009, 20:22 |
Ap is the value after under-relaxation. for example , Ap/0.6 Ap/0.6-Sigam (A neighbour) >0
November 8, 2009, 06:03 |
Mohammad Reza Hadian
Rep Power: 17 |
also, it is recommended to add Delta_F (Fe-Fw+Fn-Fs+Ft-Fb) to Ap.
November 14, 2009, 06:48 |
S.M. Hadi Meshkati
Rep Power: 16 |
November 15, 2009, 02:47 |
#5 | |
i do not agree with you. if a 1 is used. the simplec will destinated to divergence |
November 18, 2009, 21:58 |
yu
Rep Power: 16 |
November 19, 2009, 00:48 |
Rep Power: 17 |
Delta_F=Fe-Fw+Fn-Fs+Ft-Fb and these are convective fluxes passes control volume faces. actually this is the continuity equation and should be zero but it is not zero during the iterations. have a look on the book by Versteeg and Malalaskera.
also, note that in unsteady form of equation you have a A0 which added to Ap. so that Ap-SUM(Anb) will not be zero. moreover a relaxation factor is recommended. |
Best front tracking method for surface evaporation | Komkamol | Main CFD Forum | 0 | July 17, 2009 10:23 |
Code for most powerfull FDV Method | D.S.Nasan | Main CFD Forum | 6 | September 4, 2008 02:08 |
Help about the preconditioner in gmres method | Dan Gao | Main CFD Forum | 3 | July 5, 2008 01:18 |
hess-smith method and fvm method | yangqing | FLUENT | 0 | March 20, 2002 19:25 |
Is SIMPLEC method suitable for turbomachinery? | lhb | Main CFD Forum | 14 | February 15, 2001 19:59 |
