Mesh Size & Turn Around Time
Old   December 23, 2009, 09:14
Default Mesh Size & Turn Around Time
Andy Robertson
AndyR is on a distinguished road
Folks,
Perhaps this would be better as a poll, but I don't think we have that for CFD-Online yet.
I have been asked by my management who is CFD illiterate to show where our computational facilities are relative to some "state of the art". I think this might be best described in terms of what a "state of the art" mesh size might be, and what a "a state of the art" turn around time might be, and then compare that to what we can do with our available resources. I thought a time line might also be helpful.
So I ask you;
What would you consider current mesh sizes for:
Grand Challenge
Large but infrequent (once a year within an analysis team)
Large but frequent (4 or 5 times a year within an analysis team)
Daily driver / typical mesh size
Quick and dirty problem
And then turn around time for the problem
My thinking is that for 2010 a state of the art facility should be able to run:
Grand Challenge - 1 billion cells / 2 months
Large infrequent - 50 million cells / 3 to 4 weeks
Large frequent - 10 million cells / 2 weeks
Daily driver - 3 million cells / 1 week
Quick and Dirty - 500K cells / 2 days
Note my times are non-linear. I am assuming that the smaller problems are sharing compute resource with more jobs and the Grand Challenge gets every clock cycle available.
I am still thinking about what those numbers would have been in 2000 and 1990.
Any help is appreciated
Thanks
- AndyR
AndyR is offline   Reply With Quote
Old   January 2, 2010, 19:09
Eric Nutsch
ericnutsch is on a distinguished road
Send a message via Skype™ to ericnutsch
There is a way to do it, I have never taken the time to figure it out but here is one:
http://www.cfd-online.com/Forums/ope...-openfoam.html
The resolution sounds accurate. I suppose the time depends the solution type, residual targets, transient values, hardware, etc.
I recently built a high end singe processor desktop system with enough ram to handle 12million cells. If the solution time is indeed linear with respect to the number of cells, I should be able solve a 12million cell steady state solution in a little less than 3 hours(running all 4 cores). Obviously those numbers go up when transients are involved, but 2 weeks(336hr) seems pretty significant for a state of the art facility.
Hope that helps!
FYI: http://www.cfd-online.com/Forums/har...benchmark.html
ericnutsch is offline   Reply With Quote
Old   January 3, 2010, 16:59
Andrew Campbell
acampbell is on a distinguished road
As always the answer will be "it all depends"!
If it is a complicated multiphysics problem, you can spend a few months getting a commercially reasonable result with a couple of million cells/nodes.
Also the experience of the operator will also impact on the time it takes to complete the work, also if you have a previous example this helps a lot......
acampbell is offline   Reply With Quote
Old   January 6, 2010, 18:43
Eric Nutsch
AndyR,
I figured out how to start a poll:
Click the "Thread Tools" in the submenu at the top of the forum.
Then click "Add a poll to this thread"
It will only let you do it if you are the thread starter(obvious but relevant).
Cheers!
compute resource, history, mesh size
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Is there a way to write the time step size, time a may FLUENT 6 November 22, 2009 11:52
Mesh size for particulate flow simulations Shahri Main CFD Forum 0 March 24, 2009 17:40
[snappyHexMesh] SnappyHexMesh not generate mesh first time mavimo OpenFOAM Meshing & Mesh Conversion 4 August 26, 2008 07:08
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
