finite volume discretizing on non-conservative eq.
Old   February 1, 2010, 22:03
Default finite volume discretizing on non-conservative eq.
bearcat
bearcat is on a distinguished road
Send a message via MSN to bearcat
Hello.
I am now working on the discretizing formulation to solve incompressible flow by pseudo-compressibility method in a velocity-pressure coupled way. From my experience, we need to linearize the eq before discretization using Jacobin matrix.
for example:
suppose U is matrix of primitive variables
we often change ("dd" means 1st order partial differencing here)
ddU/ddt+ddE/ddX+ddF/ddY=RHS (1) --conservative
into
ddU/ddt+A(ddU/ddX)+B(ddU/ddY)=RHS (2) (in which A=ddE/ddU, B=ddF/ddU) --non-conservative
Theoretically, conservative form is needed before applying the FVM. I tried to discretize (1) without knowing E, F as functions of U first, and then applied E=U(ddE/ddU) and F=U(ddF/ddU) for the facial flux expression. I found that the final formulation will be the same with discretizing (2). Is this correct or wrong?
I did this because I've to handle the pressure term in solving N-S eq. I want to include the pressure term into E and F, rather than leaving it as a separated term. I think this way may make it simpler and doesn't require other tricks to discretize the pressure term. Is my idea correct? Can it work?
Thank you very much.
bearcat is offline   Reply With Quote
Old   February 2, 2010, 17:43
bearcat
I heard that some solvers use a technique named "momentum interpolation" to compute the pressure. Very few CFD books talk about this. Not sure if it will work as in a coupled solver using pseudo-compressibility.
Old   February 3, 2010, 21:40
Default could be right
gory is on a distinguished road
What you do could be right since E=AUand F=BU are exact relations for the Euler equations: a flux vector is exactly equal to the product of the Jacobian and the state vector.
I remember that the Steger-Warming flux vector splitting scheme are constructed by using these relations.
gory
gory is offline   Reply With Quote
finite volume VS finite element solomon FLUENT 4 April 3, 2015 00:10
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
