could you explain a everyday life phenomenon?
Old   March 7, 2004, 23:37
Default could you explain a everyday life phenomenon?
askquestion
When turn on a faucet, water fall down to a flat tub. Then a flat area surrounded by a circular boundary is formed and the boundary is just like a wall that separate the water outside and the relative dry area inside. can anyone explain it to me using fluid mechancs knowledge? It may also be a type-change example,i.e. elliptic & Hyperbolic type equations apply to each zone.
Old   March 9, 2004, 13:36
Default Re: could you explain a everyday life phenomenon?
Dean
That circular wall of water is known as a "bore" and is described in many standard hydro texts.
transient phenomenon using steady state simulations beguxa FLUENT 2 April 15, 2010 02:22
boiling and defogging phenomenon elisenda OpenFOAM Running, Solving & CFD 0 January 21, 2010 10:15
Difference between life as a postgrad and postdoc KK Main CFD Forum 0 January 26, 2009 07:44
