Experimental validation
Old   February 12, 2010, 01:42
Default Experimental validation
mach
mach13 is on a distinguished road
Hi all and respected sirs,
I am working on a problem ( of a geometry on the exhaust side) with experimental data available. But my inlet and outlet pressures ( I've used pressure inlet and pressure outlet conditions ) per se are very close to each other and also to atmos pressure. Inlet - 14.76 psi & outlet - 14.51 psi. Though computed pressures are matching within 2% of experimental values will this narrow pressure range create a road - block for my problem? ( i have used Gambit & Fluent).
Thanks in advance and take care..............
mach13 is offline   Reply With Quote
forum for experimental validation? Jorn Main CFD Forum 0 July 19, 2007 14:56
Experimental & numerical results Amy CFX 2 September 1, 2005 08:52
experimental data for code validation Ambrose Main CFD Forum 4 May 4, 2004 14:33
experimental validation of cfx code ravindra tupake CFX 2 August 18, 2002 09:11
CFD experimental validation Massimiliano Gasparetti Main CFD Forum 5 November 24, 1998 07:07
