February 12, 2010, 13:10 |
Literature on Solidification/Melting
I am looking for literature on Solidification/Melting process involving gas phase as well. For example, a container filled with half liquid and 1/2 gas on top cooled and solidified. such a system representing 3 phase in reality - liquid-solid-gas. I found a lot of literature for pure melting or solidification with liquid-solid alone but not with additional gas component. Kindly suggest me some literature/experiments which I can use for model validation. Thanks, CFDtoy
CFDtoy |
February 12, 2010, 14:14 |
Re: Literature on Solidification/Melting
James Zhong
I am also looking for three-phase models for melting/solidifcation with gas. My application is like this: a laser is scanning a powder bed. It is part of laser cladding with pre-placed powder. I think it is difficult to track every single powder particle. So it is better to use a mixture continuum model. My first question is under what conditions (when) the gas between particles escape out from molten powder material. Does anyone know literature dealing with this kind of problem? Thanks!
February 12, 2010, 14:45 |
Literature on Experimental data
#3 | |
Hi James,
You can use commercial CFDwares to run 3 phase ..some of them already have 3 phase models. I am looking for experimental values to validate my modeling part. Fluent uses contiuum approach..i am doing multi-fluid approach, treating liquid,gas, solid separate and using interaction terms in the segregated momentum eqns to solve the flow problem with phase change. Kindly let me know if you have some experimental literature data for this. Thanks. Quote:
CFDtoy |
February 15, 2010, 12:48 |
Re:Literature on Solidification/Melting
James Zhong
CFDtoy,
Thank you for your helpful information! Unfortunately, I don't have experimental literature data at hand right now. James |
March 11, 2010, 13:37 |
Kale Pushpak
hi James and CFDtoy
i am working with 2 phase model of solidification/melting. which is "solidification in rectangular enclosure" do you have any literature regarding the procedure for application of the boundary conditions? i got tutorial of continuous casting but for further problems it is not that useful. only solid/melting model is used or in addition to this any other model is required. will be very thankful to you. kale pushpak |
Dynamic Meshing Literature | oxidising agent | ANSYS Meshing & Geometry | 3 | November 20, 2009 14:58 |
searching literature: AXIAL flow around a cylinder | Ralf Schmidt | Main CFD Forum | 0 | June 1, 2006 02:36 |
Literature for Turbulence in closed walls or space | Arnab | Siemens | 0 | March 11, 2004 18:34 |
Literature for Turbulent jets/flows | Arnab | Siemens | 2 | March 9, 2004 12:16 |
Help for Labyrinth design literature | S.P.Asok | Main CFD Forum | 8 | September 13, 2001 00:15 |
