turbulent kinetic energy and turbulent dissipation rate
Old   February 23, 2010, 18:02
Default turbulent kinetic energy and turbulent dissipation rate
D_L
D_L is on a distinguished road
Hi all, I am a Star CCM+ user and currently doing a project on wind turbine wakes. In the Star CCM+, I have to assign a value to both turbulent kinetic energy (TKE) and turbulent dissipation rate (TDR) for simulation, but I have no ideas what values should they be.
Could anyone suggest me on how to define these values? If these values are chosen incorrectly, how will it affect the results?
Thank you.
D_L is offline   Reply With Quote
Old   February 24, 2010, 17:43
N/A
harishg is on a distinguished road
If the values are not chosen to represent the flow conditions approximately, the wind turbine wake predictions will be different. In outflow zerogradient is usually used. At walls you have k=0 and dissipation has to be calculated from asymptotic expressions to avoid singularity. At the inflow you need to know the precise value of k/epsilon/L.
harishg is offline   Reply With Quote
Old   March 2, 2010, 17:41
D_L
Than you for answering. How can I get a precise value of the TKE and TDR at the inflow?
I looked at some technical reports but they did not mention the values of TKE and TDR used in their CFD simulations.
Old   March 3, 2010, 20:39
N/A
Look for the NREL reports. They did extensive measurements. I am not sure of the exact details of the experiment but you should be able to find some useful information. Another option will be to look into the atmospheric rough boundary layer equations and check in the literature on ways people have used these equations for problem definition.
Old   July 14, 2010, 00:55
nvtrieu is on a distinguished road
I've been working with Star-CCM+ for several months. I also have the same question with D_L. How do I calculate the value for k,w,epsilon for the boundaries? could any one give me the answer?
Thanks in advance!
Trieu
email: trieuckgt@gmail.com
nvtrieu is offline   Reply With Quote
Old   July 17, 2010, 02:35
Default Turbulence Intensity
CCTech
CCTech_Pune is on a distinguished road
Hi
Please refer to "Development and Validation of WECC Variable Speed Wind Turbine Dynamic Models for Grid Integration Studies". This give good insight.
For length scales, you should consider using a length scale which is based on the size of the object over which flow is moving.
Thanks
CCTech_Pune is offline   Reply With Quote
LES and total turbulent kinetic energy Boerge FLUENT 1 September 8, 2012 11:41
turbulent kinetic energy and dissipation panneerselvam.R CFX 1 July 22, 2005 01:55
turbulent kinetic energy and this dissipation hicham FATNASSI Main CFD Forum 0 December 29, 2000 06:47
calculation of (turbulent) dissipation energy ? max Main CFD Forum 3 August 18, 1999 09:42
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 13:22
