blasius equation
Old   March 5, 2010, 00:40
Default blasius equation
varun
varunjain89 is on a distinguished road
hello....
i have written code for boundary layer eqns over flat plate, and its working fine.
now i need to compare my results with blasius solution, so where or how can i get the data for analytical blasius solution.
thanks in advance
varun
varunjain89 is offline   Reply With Quote
Old   March 5, 2010, 01:16
pricegr is on a distinguished road
http://www.imc.pcz.czest.pl/instytut...bl/afm_bl7.pdf
pricegr is offline   Reply With Quote
Old   March 5, 2010, 02:37
varun
i don't get it....
look my free stream velocity is 100,
pressure and density are sea level value...
i need to plot boundary layer profile @ different values of x...
or basically i need to calculate f' @ different values of x along the flat plate... so how can i calculate f'....
isn't there any site where i can directly get the data files, or data.
Old   March 5, 2010, 12:11
http://www.engr.sjsu.edu/nikos/cours...20solution.htm
Old   March 5, 2010, 13:43
varun
hey thanks a lot.... i really appreciate your help
Old   March 5, 2010, 21:56
Thumbs up There is a code for Blasius solution
gory is on a distinguished road
This may be what you want.
You can download a code that computes the Blasius solution (u,v,f,f',f'') at a 'given' point in the domain:
http://www.ossanworld.com/cfdbooks/cfdcodes.html
Good luck.
gory
gory is offline   Reply With Quote
Old   March 6, 2010, 02:35
varun
hey, thanks, i did got what i wanted but this link is also very helpful.... thanks a lot
Old   May 1, 2010, 15:07
Default help me
shahrouz
shahrouzalimo is on a distinguished road
Dear Sir.
I wrote a Matlab code for solving Blasius eq( f'''+0.5f*f''=0 ,f(0)=f'(0)=0,f'(inf)=1 )
1. I cannot write a function state , Matlab errors me y hasn't defined!?
2. how we replace f''(0)=0.322 instead of f'(inf)=1 ?
Can u help me ?
pls
shahrouzalimo is offline   Reply With Quote
Old   May 1, 2010, 18:02
DoHander is on a distinguished road
In order to solve Blasius in Matlab you need to discretize your solution with a Finite Differences formula, or to write the equation as a system of 3 ordinary differential equations and use one of the ODE solvers available in Matlab.
Do
DoHander is offline   Reply With Quote
Old   May 2, 2010, 11:13
The trick is described in this book -> http://www.cfdbooks.com
Anyway, use f''(0)=0.3320573362151946, and solve the system of ODE.
Good luck.
gory
Old   May 2, 2010, 12:32
Smile
  #11
shahrouz
Dear groy
http://www.cfdbooks/.com I couldn't find the book could u give me the name of it?
Thanks alot!
The trick is described in this book -> http://www.cfdbooks/.com
Good luck.
gory
Old   May 2, 2010, 12:59
Exclamation
  #12
shahrouz
Dear DoHander
Have u write the code?
How can I write 3 ordinary differential equation?
I've written this code :
function dy = state(t,y)
dy = zeros(3,1); % a column vector
dy(1) = y(2);
dy(2) = y(3);
dy(3)=-0.5*y(1)*y(3);
but MatLab says that u have to input y ?
Best regards
Do
Old   May 2, 2010, 15:18
vo2
vo
vo2 is on a distinguished road
I am so glad for website like this. i have almost same problem and i make google search and find this website. thank you so much for making this available. i now save many time sent.
vo2 is offline   Reply With Quote
Old   May 2, 2010, 18:15
Sorry, the link was in error. Try this one.
http://www.ossanworld.com/cfdbooks/cfdbooks.html
It's a book called "I do like CFD, VOL.1" which I personaly find very useful.
Or you can use or consult the code posted on that website,
which is this:
http://www.ossanworld.com/cfdbooks/c...blasius_v1.f90
Regards,
gory
Old   June 5, 2011, 12:37
Udhab Adhikari
udhab619 is on a distinguished road
i need a c code for blasius solution over a flat plate. if anybody of u have it or know the link plz let me know.
udhab619 is offline   Reply With Quote
Old   June 25, 2012, 09:42
Default Vertical velocity of boundry layer over a horizontal flat plate
  #16
Mohsen Hashemzadeh
mohsen.hashemzadeh is on a distinguished road
Hello.
I wrote a code for blasius equation(2f'''+ff''=0) and i got the answers.
I want to find vertical velocity(v),but the velocity profile of v did not match with what really happen,Because out of boundary layer,there should be v=0,but using solution of Blasius Equation,v is inequal to 0.
How could I solve this problem??
mohsen.hashemzadeh is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Viscosity and the Energy Equation Rich Main CFD Forum 0 December 16, 2009 14:01
continuity equation Rafal Main CFD Forum 4 November 29, 2006 09:27
Blasius equation. Lawal Main CFD Forum 7 November 15, 2004 14:45
