Wall-Material heat lost
Old   March 29, 2010, 12:16
Default Wall-Material heat lost
Thierry Corbeil
thierrycorbeil is on a distinguished road
Hi Everyone
I’m a beginner (brand new) with CF Design, I’m trying to simulate heat lost (heat gain) from the surroundings, room air volume (in gray) to the small enclosure (part in black).
I’ve started with boundary conditions of 0 psi and 80F for the top surface of the surrounding volume (room) and -5F for the air volume inside the black part
The simulation is not working, I can not see the temperature gradient in the wall (black part) and the ‘heat lost’ cause by the surrounding
All this manipulation ans simulation is to get use with the software afterward I want to implement TE’s module for cooling base on the capacities needed
Thank you
thierrycorbeil is offline   Reply With Quote
Wall Material Maple FLUENT 4 March 13, 2009 05:39
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
