negative heat transfer coefficient in contour
Old   April 21, 2010, 09:48
Default negative heat transfer coefficient in contour
sharad kumar
sharad_kumar101 is on a distinguished road
I wanted to ask that i am doing simlation of a ammonia containing shell and tube heat exchanger in 2-d in cfd..we have given the boundary condition as temperature of ammonia at inlet and the temperature of tube walls we have also given the inlet velocity of ammonia and also given a phase change of ammonia vapor into liquid by condensation near the tube walls.there is a flow of water inside the tubes..but at last we are getting negative heat transfer cofficient in contour in the heat exchanger...what can be the reason behind it and how to rectify it.
sharad_kumar101 is offline   Reply With Quote
Old   April 21, 2010, 09:58
sharad kumar
Originally Posted by sharad_kumar101 View Post
I wanted to ask that i am doing simlation of a ammonia containing shell and tube heat exchanger in 2-d in cfd..we have given the boundary condition as temperature of ammonia at inlet and the temperature of tube walls we have also given the inlet velocity of ammonia and also given a phase change of ammonia vapor into liquid by condensation near the tube walls.there is a flow of water inside the tubes..but at last we are getting negative heat transfer cofficient in contour in the heat exchanger...what can be the region behind it and how to rectify it.
The velocity is 0.8 m/sand the inlet pressure is 14 bar..ammonia inlet temperature is 363k..and the tube wall temperature is 300k.
2-d, shell and tube
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
negative heat transfer coefficient Sigrid Andreae CFX 1 February 26, 2005 07:13
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
