SIMPLER Algorithm question
Old   May 20, 2004, 15:04
Default SIMPLER Algorithm question
Erik
Hi there,
I have written a code based on SIMPLER method for the flow in a duct. I have expanded my code to variable density (I added term d rho/dt in the continuity equation). The issue is when I use fixed time step the code works fine, when I use variable time step if I reduce the time step say by 10 times less then I have a small jump in my pressure, this jump goes away in the next time steps. Am I doing something wrong? Or is it the nature of SIMPLER algorithm that is so sensitive and stiff. I would like to know your feed back. My understanding is that the SIMPLER is very sensitive to term (d rho/ dt). Your help is appreciated.
Old   May 23, 2004, 03:57
Default Re: SIMPLER Algorithm question
Rami
Erik,
Not specific answer to your query, but the following paper might be helpful:
K.C. Karki and S.V. Patankar, Pressure Based Calculation Procedure for Viscous Flows at All Speeds in Arbitrary Configurations, AIAA J V27 N9, 1989, pp 1167-1174.
Rami
SIMPLE algorithm SamR Main CFD Forum 19 April 26, 2019 13:06
Question regarding the F2F particle tracking algorithm implementation. andrewryan OpenFOAM 2 October 22, 2009 01:55
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
mach-uniform algorithm for LES/DNS ilyas Main CFD Forum 0 February 22, 2007 10:53
