June 10, 2010, 02:20 |
Reason for asymmetry in symmetric geometries
say I have a symmetric geometry like a circular cylinder. the grid is perfectly symmetric around the cylinder and the inlet profile is also symmetric. still why do we get alternate vortex shedding? what is the numerical reason?
in real life scenario there is some asymmetry in the inlet flow which might trigger the asymmetric vortex shedding. but why does this happen in a perfect cfd simulation? |
June 10, 2010, 08:13 |
Rep Power: 18 |
It is true that in real life there may be some asymmetry that can trigger an asymmetry in a flow, which might not happen in a "perfectly" symmetric CFD simulation. But no CFD simulation is perfectly symmetric, due to such things as round-off error. Also, you are failing to consider the possibility that the Navier-Stokes equations can support solutions that are time-varying and only symmetric in a time-averaged sense.
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Why is the solution not symmetric? | Hp | FLUENT | 0 | February 2, 2007 14:47 |
symmetric flow around fuselage | Christoph | FLUENT | 0 | November 3, 2005 05:50 |
Gambit - Virtual Geometries (Pro's & Con's) | James Date | FLUENT | 3 | August 11, 2003 15:46 |
Symmetric problem - Assymetric results | Mark | Phoenics | 2 | July 2, 2001 09:04 |
