Solving the poisson equation on collocated grids
Old   June 16, 2010, 08:43
Question Solving the poisson equation on collocated grids
Hooman is on a distinguished road
Does anyone know of any references that shos how to use the SIMPLE method or any other methods to solve the pressure equation (Poisson equation) on collocated grids?
Thanks!
Hooman is offline   Reply With Quote
Old   June 16, 2010, 18:18
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
I am not exactly sure what you are after. You could have a look at:
http://www.cfd-online.com/Books/show_book.php?book_id=4
I believe that the book has a good explanation on the simple method and probably some explanation on solvers for the pressure equation.
If you are working in finite volume form and use collocated grids, you will likely need a stabilisation term.
Best of luck.
Julien
julien.decharentenay is offline   Reply With Quote
Old   June 16, 2010, 18:49
DoHander is on a distinguished road
Try these books:
Fletecher - Computational Techniques for Fluid Dynamics (vol II)
H. Versteeg, W. Malalasekra - An Introduction to Computational Fluid Dynamics
Do
DoHander is offline   Reply With Quote
Old   June 21, 2010, 06:40
Thank you for your replies.
Unfortunately I dont have access to the Fletcher book but I've checked the other two.
I have a discretized momentum equation (I used Crank-Nicolson for time and central differencing and 1st order upwind for space discretization) .
Am I correct in saying that Ferziger and Peric mentions that whatever discretization method's used for the momentum equation needs to be applied to the poisson equation too?
Also am I corerct in saying that the SIMPLE method needs to be used for both the pressure and the momentum equations?
Many Thanks
Old   June 29, 2010, 12:27
Murni
Murni MDT is on a distinguished road
Dear Hooman,
'Am I correct in saying that Ferziger and Peric mentions that whatever discretization method's used for the momentum equation needs to be applied to the poisson equation too?'
Yes. Poisson equation come from the pressure correction formula which is come from your discretization.
'Also am I corerct in saying that the SIMPLE method needs to be used for both the pressure and the momentum equations?'
Yes. Actually SIMPLE stand for semi-implicit method for pressure-linked equations. It's not only for pressure, it's for velocities too. There are certain steps to apply this method. You can find it in any CFD books which is discussing about SIMPLE.
Murni MDT is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
