Transient simulation
Old   August 23, 2004, 04:26
Default Transient simulation
Pramila
Hi...
i want to solve a set of transport equations containing transient and steady state equations..If i were to run the simulation as transient how do i eliminate the time derivative term d( )/dt from the steady state equation....kindly let me know..thank you. Regards-Pramila.
Old   August 26, 2004, 07:34
Default Re: Transient simulation
FV
Try to increase the time-step to infinity while solving the steady state equations, while retaining a small time-step for the transiemt part.
Old   October 1, 2010, 04:01
Unhappy
hoaiphuong
alac1407 is on a distinguished road
Please help me!
When I simulate my model.
It has an error in solver-manager...
I don't know while I set parameter, it is reasonable or not...
Thank you very much in advance !
And this is code for solution :
"&replace FLOW: Flow Analysis 1 ANALYSIS TYPE:
Option = Transient
EXTERNAL SOLVER COUPLING:
Option = None
END
INITIAL TIME:
Option = Automatic with Value
Time = 0 [s]
END
TIME DURATION:
Option = Total Time
Total Time = 10 [s]
END
TIME STEPS:
Option = Timesteps
Timesteps = 0.1 [s]
END
END
DOMAIN: Default
Coord Frame = Coord 0
Domain Type = Fluid
Location = part_1
BOUNDARY: Default Default
Boundary Type = WALL
Create Other Side = Off
Interface Boundary = Off
Location = wall part_1
BOUNDARY CONDITIONS:
HEAT TRANSFER:
Option = Adiabatic
END
MASS AND MOMENTUM:
Option = No Slip Wall
END
WALL ROUGHNESS:
Option = Smooth Wall
END
END
END
BOUNDARY: Inlet
Boundary Type = INLET
Location = inlet
FLOW REGIME:
Option = Subsonic
END
HEAT TRANSFER:
Option = Static Temperature
Static Temperature = 298 [K]
END
MASS AND MOMENTUM:
Normal Speed = Vinlet
Option = Normal Speed
END
TURBULENCE:
Option = Medium Intensity and Eddy Viscosity Ratio
END
END
END
BOUNDARY: Outlet
Boundary Type = OUTLET
Location = outlet
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Average Static Pressure
Pressure Profile Blend = 0.05
Relative Pressure = 0 [Pa]
END
PRESSURE AVERAGING:
Option = Average Over Whole Outlet
END
END
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
Reference Pressure = 1 [atm]
END
END
FLUID DEFINITION: Fluid 1
Material = Air at 25 C
Option = Material Library
MORPHOLOGY:
Option = Continuous Fluid
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Option = Thermal Energy
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = k epsilon
END
TURBULENT WALL FUNCTIONS:
Option = Scalable
END
END
INITIALISATION:
Option = Automatic
INITIAL CONDITIONS:
Velocity Type = Cartesian
CARTESIAN VELOCITY COMPONENTS:
Option = Automatic
END
STATIC PRESSURE:
Option = Automatic
END
TEMPERATURE:
Option = Automatic
END
TURBULENCE INITIAL CONDITIONS:
Option = k and Epsilon
EPSILON:
Option = Automatic
END
K:
Option = Automatic
END
END
END
END
END
OUTPUT CONTROL:
MONITOR OBJECTS:
MONITOR BALANCES:
Option = Full
END
MONITOR FORCES:
Option = Full
END
MONITOR PARTICLES:
Option = Full
END
MONITOR RESIDUALS:
Option = Full
END
MONITOR TOTALS:
Option = Full
END
END
RESULTS:
File Compression Level = Default
Option = Standard
END
TRANSIENT RESULTS: Transient Results 1
Option = Standard
OUTPUT FREQUENCY:
Option = Every Timestep
END
END
TRANSIENT STATISTICS: Transient Statistics 1
Option = Arithmetic Average
Output Variables List = Pressure
END
END
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
SOLVER CONTROL:
Turbulence Numerics = First Order
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Maximum Number of Coefficient Loops = 3
Minimum Number of Coefficient Loops = 1
Timescale Control = Coefficient Loops
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
TRANSIENT SCHEME:
Option = Second Order Backward Euler
TIMESTEP INITIALISATION:
Option = Automatic
END
END
END
END "
alac1407 is offline   Reply With Quote
about transient radiations simulation waradevivek FLUENT 0 October 17, 2011 10:16
Beginning a Transient Simulation Norflow CFX 2 October 7, 2011 00:38
initial conditions for transient simulation littlelz CFX 2 February 5, 2009 05:56
Transient simulation - pressure shifted Eric CFX 1 February 14, 2006 12:42
Charts for transient simulation Anurag CFX 2 March 28, 2005 12:09
